    Nobody knows???
    16 Posts 3 Posters 5.2k Views 3 Watching
    • karsten13K
      karsten13 @sdetweil
      if you refer to this PR: The new config param is only valid for the internal weather providers, foreign modules can use the proxy by adding the mentioned url.
      S F 2 Replies Last reply
        sdetweil @karsten13
        @karsten13 ok.
        • F
          fischi87 @karsten13
          @karsten13
          i will send u my code part and the error later. thanks for ur reply!
          i hope we can fix this problem.
          • F
            fischi87 @karsten13
            @karsten13
            var stromRequest = new XMLHttpRequest();
                      var requestURL = 'http://192.168.178.44/cm?cmnd=var1';
                      stromRequest.onreadystatechange = function () {
                        if (stromRequest.readyState === XMLHttpRequest.DONE) {
                          if(stromRequest.status === 200) {
                            var json_parse = JSON.parse(stromRequest.responseText).Var1
                            var stromverbrauch = Number(json_parse * 0.30)//.toFixed(2);
                            var verbrauch = stromverbrauch.toFixed(2);
            this is my request and the error:
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @fischi87
              @fischi87
              so I assume the code snippet is from the module.js (not from node_helper.js). The url with IP 192.168.178.44 is pointing to another device in your network and is therefore different to the IP where mm is running?
              If mm has the same IP you could try localhost instead, if the IP’s are different you can try this:
              var requestURL = location.protocol + "//" + location.host + "/cors?url=http://192.168.178.44/cm?cmnd=var1";
              The 2. option with the cors url works only with the develop branch of mm (will be in the next official relase coming 1. April).
              F 1 Reply Last reply
              • F
                fischi87 @karsten13
                @karsten13
                thats right, its from the module.js. i read i can fix this issue with the node_helper.js but i dont know how to write the code down in the node_helper.js to get the result from my url.
                i will try ur answer later.
                i know how to write code in the node_helper.js form the request?
                thanks
                • F
                  fischi87
                  @karsten13 said in Nobody knows???:
                  var requestURL = location.protocol + “//” + location.host + “/cors?url=http://192.168.178.44/cm?cmnd=var1”;
                  now I get this error:
                  cannot get /cors.
                  karsten13K S 2 Replies Last reply
                  • karsten13K
                    karsten13 @fischi87
                    @fischi87
                    you switched to develop and pulled the latest version of mm? Looks like not.
                      sdetweil @fischi87
                      @fischi87 here is how to get to develop branch, depending on how u installed
                      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                      • F
                        fischi87 @sdetweil
                        after switch to develop no MagicMirror display anymore? no autocrat, nothing?
                        electron problem!
                          sdetweil @fischi87
                          @fischi87 and u have to npm install after switch
                          • F
                            fischi87
                            I get it and now it also display my problem from the beginning, thanks @sdetweil and @karsten13
                              sdetweil @fischi87
                              @fischi87 does this mean that the develop branch solves your problem?
