    Nobody knows???
    16 Posts 3 Posters 5.1k Views 3 Watching
    • karsten13K Online
      karsten13 @fischi87
      @fischi87
      you provide no infos related to your problem, we are not clairvoyant
      • karsten13K Online
        karsten13 @sdetweil
        if you refer to this PR: The new config param is only valid for the internal weather providers, foreign modules can use the proxy by adding the mentioned url.
        S F 2 Replies Last reply Reply Quote 0
          sdetweil @karsten13
          @karsten13 ok.
          • F Offline
            fischi87 @karsten13
            @karsten13
            i will send u my code part and the error later. thanks for ur reply!
            i hope we can fix this problem.
            • F Offline
              fischi87 @karsten13
              @karsten13
              var stromRequest = new XMLHttpRequest();
                        var requestURL = 'http://192.168.178.44/cm?cmnd=var1';
                        stromRequest.onreadystatechange = function () {
                          if (stromRequest.readyState === XMLHttpRequest.DONE) {
                            if(stromRequest.status === 200) {
                              var json_parse = JSON.parse(stromRequest.responseText).Var1
                              var stromverbrauch = Number(json_parse * 0.30)//.toFixed(2);
                              var verbrauch = stromverbrauch.toFixed(2);
              this is my request and the error:
              • karsten13K Online
                karsten13 @fischi87
                @fischi87
                so I assume the code snippet is from the module.js (not from node_helper.js). The url with IP 192.168.178.44 is pointing to another device in your network and is therefore different to the IP where mm is running?
                If mm has the same IP you could try localhost instead, if the IP’s are different you can try this:
                var requestURL = location.protocol + "//" + location.host + "/cors?url=http://192.168.178.44/cm?cmnd=var1";
                The 2. option with the cors url works only with the develop branch of mm (will be in the next official relase coming 1. April).
                • F Offline
                  fischi87 @karsten13
                  @karsten13
                  thats right, its from the module.js. i read i can fix this issue with the node_helper.js but i dont know how to write the code down in the node_helper.js to get the result from my url.
                  i will try ur answer later.
                  i know how to write code in the node_helper.js form the request?
                  thanks
                  • F Offline
                    fischi87
                    @karsten13 said in Nobody knows???:
                    var requestURL = location.protocol + “//” + location.host + “/cors?url=http://192.168.178.44/cm?cmnd=var1”;
                    now I get this error:
                    cannot get /cors.
                    karsten13K S 2 Replies Last reply Reply Quote 0
                    • karsten13K Online
                      karsten13 @fischi87
                      @fischi87
                      you switched to develop and pulled the latest version of mm? Looks like not.
                        sdetweil @fischi87
                        @fischi87 here is how to get to develop branch, depending on how u installed
                        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                        • F Offline
                          fischi87 @sdetweil
                          after switch to develop no MagicMirror display anymore? no autocrat, nothing?
                          electron problem!
                            sdetweil @fischi87
                            @fischi87 and u have to npm install after switch
                            • F Offline
                              fischi87
                              I get it and now it also display my problem from the beginning, thanks @sdetweil and @karsten13
                                sdetweil @fischi87
                                @fischi87 does this mean that the develop branch solves your problem?
