Nobody knows???
16 Posts 3 Posters 3.0k Views 3 Watching
  • F Offline
    fischi87
    Hello again, I don’t think that nobody knows how to fix this problem. please help me.
    my problem is still the Access-Control-Allow-Origin error. how can I or where I have to write down the access control allow? the problem is, chromium block my request (chrome) is loaded but not chromium to display my request.
    thank guys
    S K 2 Replies Last reply Feb 24, 2022, 8:32 PM Reply Quote 0
      sdetweil @fischi87
      @fischi87 this is servers rejecting requests from clients who do not have dns entries matching their IP address (cross origin)
      sometimes there is a proxy server on the web that can reissue your request from a known server.
      in the next MM release is a built in service that appears to do that for you.
      U have to download the develop branch and add a new config parm to enable it for a module.
      K 1 Reply Last reply Feb 24, 2022, 8:55 PM Reply Quote 0
      • K Offline
        karsten13 @fischi87
        @fischi87
        you provide no infos related to your problem, we are not clairvoyant
        F 1 Reply Last reply Feb 25, 2022, 5:41 AM Reply Quote 0
        • K Offline
          karsten13 @sdetweil
          if you refer to this PR: The new config param is only valid for the internal weather providers, foreign modules can use the proxy by adding the mentioned url.
          S F 2 Replies Last reply Feb 24, 2022, 8:59 PM Reply Quote 0
            sdetweil @karsten13
            @karsten13 ok.
            • F Offline
              fischi87 @karsten13
              @karsten13
              i will send u my code part and the error later. thanks for ur reply!
              i hope we can fix this problem.
              • F Offline
                fischi87 @karsten13
                @karsten13
                var stromRequest = new XMLHttpRequest();
                          var requestURL = 'http://192.168.178.44/cm?cmnd=var1';
                          stromRequest.onreadystatechange = function () {
                            if (stromRequest.readyState === XMLHttpRequest.DONE) {
                              if(stromRequest.status === 200) {
                                var json_parse = JSON.parse(stromRequest.responseText).Var1
                                var stromverbrauch = Number(json_parse * 0.30)//.toFixed(2);
                                var verbrauch = stromverbrauch.toFixed(2);
                this is my request and the error:
                K 1 Reply Last reply Feb 25, 2022, 7:51 PM Reply Quote 0
                • K Offline
                  karsten13 @fischi87
                  @fischi87
                  so I assume the code snippet is from the module.js (not from node_helper.js). The url with IP 192.168.178.44 is pointing to another device in your network and is therefore different to the IP where mm is running?
                  If mm has the same IP you could try localhost instead, if the IP’s are different you can try this:
                  var requestURL = location.protocol + "//" + location.host + "/cors?url=http://192.168.178.44/cm?cmnd=var1";
                  The 2. option with the cors url works only with the develop branch of mm (will be in the next official relase coming 1. April).
                  F 1 Reply Last reply Feb 26, 2022, 6:42 AM Reply Quote 0
                  • F Offline
                    fischi87 @karsten13
                    @karsten13
                    thats right, its from the module.js. i read i can fix this issue with the node_helper.js but i dont know how to write the code down in the node_helper.js to get the result from my url.
                    i will try ur answer later.
                    i know how to write code in the node_helper.js form the request?
                    thanks
                    • F Offline
                      fischi87
                      @karsten13 said in Nobody knows???:
                      var requestURL = location.protocol + “//” + location.host + “/cors?url=http://192.168.178.44/cm?cmnd=var1”;
                      now I get this error:
                      cannot get /cors.
                      K S 2 Replies Last reply Feb 26, 2022, 3:13 PM Reply Quote 0
