    Nobody knows???
    16 Posts 3 Posters 4.3k Views 3 Watching
    • F Offline
      fischi87 @karsten13
      @karsten13
      i will send u my code part and the error later. thanks for ur reply!
      i hope we can fix this problem.
      • F Offline
        fischi87 @karsten13
        @karsten13
        var stromRequest = new XMLHttpRequest();
                  var requestURL = 'http://192.168.178.44/cm?cmnd=var1';
                  stromRequest.onreadystatechange = function () {
                    if (stromRequest.readyState === XMLHttpRequest.DONE) {
                      if(stromRequest.status === 200) {
                        var json_parse = JSON.parse(stromRequest.responseText).Var1
                        var stromverbrauch = Number(json_parse * 0.30)//.toFixed(2);
                        var verbrauch = stromverbrauch.toFixed(2);
        this is my request and the error:
        • karsten13K Offline
          karsten13 @fischi87
          @fischi87
          so I assume the code snippet is from the module.js (not from node_helper.js). The url with IP 192.168.178.44 is pointing to another device in your network and is therefore different to the IP where mm is running?
          If mm has the same IP you could try localhost instead, if the IP’s are different you can try this:
          var requestURL = location.protocol + "//" + location.host + "/cors?url=http://192.168.178.44/cm?cmnd=var1";
          The 2. option with the cors url works only with the develop branch of mm (will be in the next official relase coming 1. April).
          • F Offline
            fischi87 @karsten13
            @karsten13
            thats right, its from the module.js. i read i can fix this issue with the node_helper.js but i dont know how to write the code down in the node_helper.js to get the result from my url.
            i will try ur answer later.
            i know how to write code in the node_helper.js form the request?
            thanks
            • F Offline
              fischi87
              @karsten13 said in Nobody knows???:
              var requestURL = location.protocol + “//” + location.host + “/cors?url=http://192.168.178.44/cm?cmnd=var1”;
              now I get this error:
              cannot get /cors.
              karsten13K S 2 Replies Last reply Reply Quote 0
                karsten13 @fischi87
                @fischi87
                you switched to develop and pulled the latest version of mm? Looks like not.
                  sdetweil @fischi87
                  @fischi87 here is how to get to develop branch, depending on how u installed
                  https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                  • F Offline
                    fischi87 @sdetweil
                    after switch to develop no MagicMirror display anymore? no autocrat, nothing?
                    electron problem!
                      sdetweil @fischi87
                      @fischi87 and u have to npm install after switch
                      • F Offline
                        fischi87
                        I get it and now it also display my problem from the beginning, thanks @sdetweil and @karsten13
