    Advise for a voice assistant
    21 Posts 7 Posters 9.3k Views 9 Watching
    • T Offline
      THeStigh @thedoorsfanatic
      @thedoorsfanatic Snowboy can be tricky, but @sean has made some good troubleshooting guides on the page for MMM-Hotword. But you can delete the MMM-Hotword folder and try to re-install it following these instructions to do it quite manually. If it fails, you at least will get a clear picture of where it actually failed:
      cd ~/MagicMirror/modules/
      sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
      git clone https://github.com/eouia/MMM-Hotword.git
      cd MMM-Hotword
      npm install
      cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
      npm install --save-dev electron-rebuild
      npm install nan
      ./node_modules/.bin/electron-rebuild
      • thedoorsfanaticT Offline
        thedoorsfanatic
        This is the error code:
        snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
        node-pre-gyp install --fallback-to-build
        node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
        node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.15.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
        node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
        internal/modules/cjs/loader.js:583
        throw err;
        Error: Cannot find module ‘nan’
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
        at Function.Module._load (internal/modules/cjs/loader.js:507:25)
        at Module.require (internal/modules/cjs/loader.js:637:17)
        at require (internal/modules/cjs/helpers.js:22:18)
        at [eval]:1:1
        at Script.runInThisContext (vm.js:96:20)
        at Object.runInThisContext (vm.js:303:38)
        at Object. ([eval]-wrapper:6:22)
        at Module._compile (internal/modules/cjs/loader.js:689:30)
        at evalScript (internal/bootstrap/node.js:587:27)
        gyp: Call to ‘node -e “require(‘nan’)”’ returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        throw err;
        at [eval]:1:1
        gyp ERR! configure error
        gypgyp ERR! stack Error: gyp failed with exit code: 1
        gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
        ERR!gyp ERR!configure error
        stack at ChildProcess.emit (events.js:189:13)
        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.14.98-v7+
        gyp ERR!gyp stack Error: gyp failed with exit code: 1
        ERR!gyp commandERR! “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
        gyp gypERR! ERR!stack at ChildProcess.emit (events.js:189:13)
        cwdgyp /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
        ERR! gypstack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        ERR! node -v v10.15.2
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
        gyp ERR! node -v v10.15.2
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)
        node-pre-gyp ERR! stack at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
        node-pre-gyp ERR! stack at ChildProcess.emit (events.js:189:13)
        node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:970:16)
        node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        node-pre-gyp ERR! System Linux 4.14.98-v7+
        node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
        node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
        node-pre-gyp ERR! node -v v10.15.2
        node-pre-gyp ERR! node-pre-gyp -v v0.6.39
        node-pre-gyp ERR! not ok
        npm WARN MMM-Hotword@1.1.0 No repository field.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! snowboy@1.3.1 install: node-pre-gyp install --fallback-to-build
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the snowboy@1.3.1 install script.
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          bibi
          @ejay-ibm, @THeStigh i have installed MMM-Hotword. I hope correctly? as i got only warning via npm like
          pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
          npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
          npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
          npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
          I am not sure how i can test it tho?
          Or there is nothing to expect with only MMM-hotword installed?
          (sorry if my question is stupid :) )
          S ? 2 Replies Last reply Reply Quote 0
            sdetweil @bibi
            @bibi start mirror in dev mode
            npm start dev
            Select the console tab in the developers window
            You should see MMM-Hotword sending notifications of the words it recognizes
            • ? Offline
              A Former User @bibi
              @bibi
              You can ignore some WARN unless your program is working.
                bibi
                @ejay-ibm, i wanted to follow your good practice and update MM to latest (ok) and OS to stretch (ok) but now it pm2 won’t start MM automatically as it did in the past… would kindly help me to solve this issue before i can install mk2?
                thx alot for any help as well
                  Mykle1 Project Sponsor Module Developer @bibi
                  @bibi
                  https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                    bibi
                    @Mykle1, thx for your post. It appears that when i want to check npm version, the system issues :
                    pi@raspberrypi:~ $ npm -v
                    -bash: npm: command not found
                    Therefore something went wrong during the system upgrade to stretch.
                    If i am not wrong npm comes along with nodejs which i have current version
                    pi@raspberrypi:~ $ nodejs -v
                    v8.11.1
                    I think i would just install it again but i don’t know if I should do it from /home/pi or from inside /home/pi/MagicMirror ?
                      @bibi said in Advise for a voice assistant:
                      pi@raspberrypi:~ Here!
                        bibi
                        finally what i did and what did work is :)
                        sudo apt-get remove nodered -y
                        sudo apt-get remove nodejs nodejs-legacy -y
                        sudo apt-get remove npm -y
                        sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
                        sudo apt-get install -y nodejs
                        node -v
                        npm -v
                        • 2 / 3
