    MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.
    38 Posts 4 Posters 23.2k Views 9 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer
      Description
      A module to control spotify command : Play / Pause / Resume/ Next using Mk2assistant hook .
      This Module allow to control Spotify player on your Mirror.
      For now you can only control a single device.
      It could be your mirror if you are running Raspotify on it.
      Special thanks to @mantha who bring this idea and the base code to me.
      Big Thanks to @Sean who helped me in the module development and spent a lot of time to teach me some dev concept.
      Please bear in mind: I’m not a developer and the module might still contain issues.
      I’ll try my best to fix them but if any dev wants to help me in that task or want to help me improve this module you are more than welcome!
      Enjoy
      Ejay
      Download
      [card:ejay-ibm/MMM-SpotifyControl]
      wishmaster270W 1 Reply Last reply Reply Quote 1
      • wishmaster270W Offline
        wishmaster270 Module Developer @ejay-ibm
        @ejay-ibm you are a genius and saved me a lot of time.
        I had the same idea but no time to implement it.
        Thank you very mich
        ejay-ibmE 1 Reply Last reply Reply Quote 0
        • ejay-ibmE Offline
          ejay-ibm Project Sponsor Module Developer @wishmaster270
          @wishmaster270 Thank you let me know your feedback once tested !
          • F Offline
            F17MC
            Awesome! I have installed it and it works, but… I have a problem with MMM-AssistantMk2 + your module.
            MMM-AssistantMk2 is working. I say: Smartmirror, play music on Spotify (my command). And it works.
            But, later, if I want to say something to MMM-AssistantMk2, I can’t.
            It’s my log:
            [HOTWORD] stops listening
            Speaker error: 1
            Maybe the problem is that if the speakers are using by other “process”, MMM-AssistantMk2 have a problem to use?
            Anyway, it is perfect . I’m testing…
            • ejay-ibmE Offline
              I do not think this is an issue with the speaker.
              Could you please send the full logs from start to end ?
              Are you using pm2 ? If yes please send me error and out log. ( delete them first before restarting your mirror )
              just do pm2 show to know where they are .
              As well while you reproduce check the developer console ( Ctrl + i ) on the mirror and send me the content .
              Just reproduce the case as follow : Start Mirror , request a song, make a new request to the assistant . Quit . and send me the logs. please add as well you config.js file . You can put all in a single zip file.
              I’ll update the git. please post everything here.
              Thank you
              Ejay
              • Cr4z33C Offline
                Cr4z33
                Can someone that is NOT a Spotify Premium user please confirm whether this module works for him too or not?
                My (mirror) Google Assistant is not understanding what I want to do and I want to be sure it has nothing to do with this module.
                • ejay-ibmE Offline
                  ejay-ibm Project Sponsor Module Developer @Cr4z33
                  @Cr4z33 from here :
                  https://developer.spotify.com/documentation/web-api/quick-start/
                  “To use the Web API, start by creating a Spotify user account (Premium or Free).”
                  Note :
                  Spotify Free is supported by ads.
                  Every few tracks you play, you will be forced to be interrupted by one or two short adverts, which will also break your pleasure that you get from the music.
                  Some tracks are not be playable. You can use the desktop and web interfaces, but the mobile app will only let you listen on shuffle mode or pre-made playlists.
                  with your free account : what does it do when you say “bob marley on spotify” ?
                  Ejay
                  • Cr4z33C Offline
                    Cr4z33 @ejay-ibm
                    @ejay-ibm said in MMM-SpotifyControl . Control your Spotify music player using Mk2 assistant.:
                    Well considering that my (mirror) Google Assistant is set to Italian language it simply replies saying it doesn’t know what I want to do.
                    On the other hand if I say (in Italian) ‘Hey Google play music on Spotify’ on my living room’s Google Home Mini it works flawlessly.
                    Actually tell me how is your module supposed to accept that command if we only entered PREV_SONG, PAUSE_SPOTIFY, RESUME_SPOTIFY and PLAY_NEXT_SPOTIFY?
                    I mean I see no PLAY command there? :smiling_face_with_open_mouth_cold_sweat:
                    Also aren’t these transcriptionHook entries supposed to be entered into quotation marks?
                    I ask because I’ve got other entries there and they are ALL into quotation marks.
                    • ejay-ibmE Offline
                      @Cr4z33
                      Ok I got your point Google assisant and sdk act differently .
                      What happen when you say something to your assisant:
                      “Play bob marley on spotify”
                      It search like you would do in the google search bar
                      and return a result.
                      That is your payload for the play … spotify command.
                      Note that this command is the only one to not have a hook .
                      So what it does is returning the first result from a google search .
                      if I type “bob marley spotify” in my search bar i’m getting :
                      Bob Marley & The Wailers on Spotify
                      https://open.spotify.com/artist/2QsynagSdAqZj3U9HgDzjD
                      That is what is expected from the payload , as we build later the api call from this url .
                      I would try first to google search for "an artist on spotify in italian’ and see what it return they say to your assisant in italian the same. Usually the assistant quickly display what it find from the search you should see an url like :
                      https://open.spotify.com/(artist, track or playlist)/with an Id here .
                      regarding the syntax Quote or double quote doesn’t matter in js.
                      Both
                       transcriptionHook: {
                              PREV_SONG: {
                                 pattern: "previous song",
                                 command: "PREV_SONG"
                      or
                              PREV_SONG: {
                                 pattern: 'previous song',
                                 command: 'PREV_SONG'
                      will work the same.
                      Hope this helps
                      Ejay
                      • Cr4z33C Offline
                        Cr4z33 @ejay-ibm
                        @Cr4z33
                        Both
                        PREV_SONG: {
                        pattern: “previous song”,
                        command: “PREV_SONG”
                        or
                        PREV_SONG: {
                        pattern: ‘previous song’,
                        command: ‘PREV_SONG’
                        will work the same.
                        Hope this helps
                        Ejay
                        Sorry you misunderstood me. :smiling_face_with_open_mouth_cold_sweat:
                        What I meant is don’t we have to put ie. PREV_SONG into quotation marks like
                        "PREV_SONG": {
                        As for the Google Assistant test you are asking me are you referring to the mirror module or to my Google Home Mini device?
                        • ejay-ibmE Offline
                          @Cr4z33
                          don’t use your google home device it’s not comparable .
                          I have one as well at home and it’s working completely differently, otherwise, I would not have to write this module. So i’m refering to what interest us your Mk2 assistant on your mirror .
                          ejay
                          • Cr4z33C Offline
                            Cr4z33
                            It says something like ‘I am sorry I don’t know how to help you, but I am learning new things day by day’.
                            I am 100% sure that all the API/token details are correct and still valid (if I run MMM-NowPlayingOnSpotify it works flawlessly).
                            • ejay-ibmE Offline
                              @Cr4z33
                              What Are you saying exactly ?
                              What is the result of this if you try to type in in your google search bar ?
                              did you simply try : “bob marley spotify” ?
                              what is your search result ? in google ?
                              • Cr4z33C Offline
                                Cr4z33 @ejay-ibm
                                @ejay-ibm
                                I am saying that:
                                • If I say in Italian to MMM-AssistantMk2 play Bob Marley on Spotify then Google Assistant replies (by voice) that he doesn’t know how to help me
                                • If I search for bob marley spotify on Google then the first result I get is this link
                                • ejay-ibmE Offline
                                  @Cr4z33 try to just say “Bob Marley Spotify” so there’s no language interaction.
                                  Cr4z33C 2 Replies Last reply Reply Quote 0
                                  • Cr4z33C Offline
                                    Cr4z33 @ejay-ibm
                                    @ejay-ibm just tried and again GA says he apologizes, but he doesn’t know right now how to help me.
                                    • Cr4z33C Offline
                                      Cr4z33 @ejay-ibm
                                      @ejay-ibm perhaps it doesn’t work (yet) when using GA in another language than English?
                                      • ejay-ibmE Offline
                                        @Cr4z33 Well i’m using it in french … so I don’t think so .
                                        I need to think a bit why your payload is incorrect.
                                        Cr4z33C F 2 Replies Last reply Reply Quote 0
                                        • Cr4z33C Offline
                                          Cr4z33 @ejay-ibm
                                          @ejay-ibm sure take your time mate as I might probably not resume testing before tomorrow afternoon. ;)
                                          • F Offline
                                            F17MC @ejay-ibm
                                            @ejay-ibm I thought your module only works to play/stop/next/previous. I have tried run “Bob Marley Spotify” and nothing happens. With other artist the same.
                                            If I can test something…
                                            Pd: Spanish + Spotify premium
