    [ORDER CLOSED] Two way mirror order in Germany
    Scheduled Pinned Locked Moved Solved Hardware
    558 Posts 80 Posters 2.7m Views 60 Watching
    • CatoC Offline
      Cato Module Developer
      Sounds interesting if you send to Norway!
      @Goldjunge_Chriz he writes “Near Schweinfurt/Bavaria” almost at the end of the post.
      • yawnsY Offline
        yawns Moderator
        Mirror glas looks good. Does it have sharp/rough edges? Or are they available polished/smoothened as well?
          Dom1n1c
          I ordered mine here:
          https://www.myspiegel.de/spionspiegel-pg-2102.html
          they are offering a mirror with 8mm thickness for 216€ / sqm
          Shipping will cost 7,50€ they have own drivers, who are only tranporting glass/mirrors, so they have the knowledge.
          BTW: The “Darkness of the mirror” is not present in my case.
          DE: Du sagtest, ein 8mm Spiegel ist dunkler, hab mit einem dünneren Spiegel beim lokalen Glaser verglichen, kein unterschied.
          yawnsY 1 Reply Last reply Reply Quote 0
          • yawnsY Offline
            yawns Moderator @Dom1n1c
            @Dom1n1c said in Two way mirror order in Germany:
            Right, but the mirror they offer is way darker than the one offered by Goldjunge_chriz … at least the pictures look like that
              Dom1n1c @yawns
              @yawns I can not confirm this.
              • yawnsY Offline
                Oh, really? @DirkS for example says it is darker than ordinary mirrors
                CatoC 1 Reply Last reply Reply Quote 0
                • CatoC Offline
                  Cato Module Developer @yawns
                  @yawns Where he say that?
                  • lolobyteL Offline
                    lolobyte
                    Servus, danke für den hinweis! ich bin auch schon lange auf der Suchs nach einem vernünftigen Spiegel.
                    Bis heute nur im Ausland etwaige exemplare gefunden.
                    Hätte schon interesse an ein zwei oder drei Stück.
                    Hab einen bei ebay gekauft.
                    8mm glas, 232,50€ /m²,freier Versand, lieferung durch eigenen Fahrer des verkäufers.
                    English.
                    Hello, thank u very much for this info. I’m searchin for a very long time such a good quality of an two way mirror. The only one that i found was in the Netherlands, USA and GB.
                    I’ intresting in one. two ore more.
                    i have buy one from ebay 8mm glass, 232,50€ /m², free shipping by sellers own driver.
                    • yawnsY Offline
                      yawns Moderator @Cato
                      @Cato said in Two way mirror order in Germany:
                      Hi Cato, https://forum.magicmirror.builders/topic/756/where-to-get-cheap-acrylic-mirror-from-in-germany/34
                      His comment is below the pictures.
                      Please note this is with regards to the myspiegel.de mirror, not the one offered in this thread!
                        done
                        @Goldjunge_Chriz
                        Your mirror looks very good! Crystal clear!
                        Since you seem to know about glass, can you tell me something about how the mirror is made?
                        I learned there are two ways.
                        One version of mirrors has an evaporated coating (aufgedampfte Beschichtung) as reflection material on the glass.
                        The other version works with a reflecting foil in the middle (Verbundglas).
                        The evaporated version might be vulnerable to scratches more than the foil which is protected by the glass.
                        Can you tell me about your glass?
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 55
                        • 56
                        • 26 / 56
