    How to make the background all black
    7 Posts 4 Posters 5.0k Views 4 Watching
    • I Offline
      icripps
      Hi guy, I am trying to figure out how to change the background of the magic mirror to a very deep black(darkest black ) and I am kind of course fused because idk how to do that. I know is some css background color I have to change but which one ? .
      For the record my background is all black, but it’s not black like how I want it. When I turn off all modules, you can actually see that the monitor is on and I don’t want that.
      Help😪
        sdetweil @icripps
        @icripps in MM/css/main.css is the default color
        html {
          cursor: default;
          overflow: hidden;
          background: #000;
        which is as black as the system can make it…
        monitors and tvs will still have a glow even showing black…
        my tvs do not turn off thru programming, so I use hiding all modules for sleep, but as u noted they still glow at night.
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          icripps @sdetweil
          @sdetweil thank you , I thought I was the only one facing that issue with the display. Thanks
            retroflex Project Sponsor Module Developer @icripps
            @icripps This is because monitors use backlightning. You can use an OLED display instead if you want to build a crazy expensive mirror :)
            But in daylight the backlight is hardly visible. As a simple workaround you can try to hang your mirror somewhere else where there’s more light.
              sdetweil @retroflex
              @retroflex my TV/MM /Photoframe is a big nightlight in the hall…
                rabbit83ka
                I’m just cutting the power of the backlight with a relais and MMM-PIR-Sensor. This way the screen is really black and invisible while it’s up immediatly if the sensor detects motion.
                  retroflex Project Sponsor Module Developer @rabbit83ka
                  @rabbit83ka How do you cut the power to the backlight only?
