    updated installer script available for testing
    211 Posts 18 Posters 318.8k Views 19 Watching
      sdetweil @Neebotol
      @Neebotol great work!! Yeh, having a bad card will.make things very challenging.
      Thanks for the feedback
      • N Offline
        NathTheDude @sdetweil
        Hey @sdetweil,
        Forgot I did not get back to you. After much testing it was not feasible to use an rpi zero. Actually the ram/memory was ok, the main limitation was the cpu.
        I was using htop to monitor this during boot and normal usage, is was constantly at 100%. This caused really slow boot time and could not load the modules fully even if left for several hours.
        As soon as I went back to my rpi3 with the same modules it started very quick in comparison with no boot issues.
          sdetweil @NathTheDude
          @NathTheDude thank you for the feedback. Yes Pi 0 is really limited in what it can do.
            @NathTheDude using the new run-start.sh which launches chrome to connect to the MM serverOnly instance… I see 45% usage in htop for the initial config.
            electron has become unavailable for armv6l and node >8, so we’ve had to go split mode
            • P Offline
              PinkPumpkin
              Do anyone know if the link bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)” can be found elsewhere?
              It worked great on Raspberry Pi (1) but now it’s 404:-/
                sdetweil @PinkPumpkin
                @PinkPumpkin the scripts were moved to
                As they were removed from the last release
                This was also corrected on the 1st post of this topic.
                • P Offline
                  PinkPumpkin
                  Thanks alot;-)
                  Sowwy I didn’t see that…
                    @PinkPumpkin no problem!.. its hard to keep stuff up to date here… lots of folks use 3 year old ‘cookbooks’, that no longer work…
                    • StoffbeuteluweS Offline
                      Stoffbeuteluwe Project Sponsor @sdetweil
                      @sdetweil Hi, when I install your MM installer script on my Mac, does it install pm2 automatically.
                        sdetweil @Stoffbeuteluwe
                        @Stoffbeuteluwe it will if u select yes when prompted
                          @sdetweil oh thanks :grinning_face:
                            @Stoffbeuteluwe if you didn’t do it during the install, u can do it later with the fixuppm2 script from my site
                            StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                              @sdetweil ok sam…thanks for all your work
                                @sdetweil do you know what I am doing wrong?
                                                       \______/
                                \e[0m
                                install log being saved to /Users/patrickhahn/install.log
                                this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
                                \e[96mCheck current Node installation ...\e[0m
                                \e[0mNode currently installed. Checking version number.
                                \e[0mMinimum Node version: \e[1mv10.1.0\e[0m
                                \e[0mInstalled Node version: \e[1mv12.16.3\e[0m
                                \e[92mNo Node.js upgrade necessary.\e[0m
                                \e[96mCheck current NPM installation ...\e[0m
                                \e[0mNPM currently installed. Checking version number.
                                \e[0mMinimum npm version: \e[1mV6.0.0\e[0m
                                \e[0mInstalled npm version: \e[1mV6.14.4\e[0m
                                \e[92mNo npm upgrade necessary.\e[0m
                                \e[96mCloning MagicMirror ...\e[90m
                                Cloning into 'MagicMirror'...
                                remote: Enumerating objects: 316, done.
                                remote: Counting objects: 100% (316/316), done.
                                remote: Compressing objects: 100% (276/276), done.
                                remote: Total 316 (delta 43), reused 178 (delta 27), pack-reused 0
                                Receiving objects: 100% (316/316), 437.95 KiB | 1.48 MiB/s, done.
                                Resolving deltas: 100% (43/43), done.
                                \e[92mCloning MagicMirror Done!\e[90m
                                \e[96mInstalling dependencies ...\e[90m
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
                                npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                                npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                                npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                                npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                In file included from ../fsevents.cc:6:
                                In file included from ../../nan/nan.h:222:
                                In file included from ../../nan/nan_converters.h:67:
                                ../../nan/nan_converters_43_inl.h:22:1: warning: 'ToBoolean' is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
                                X(Boolean)
                                ../../nan/nan_converters_43_inl.h:18:12: note: expanded from macro 'X'
                                     val->To ## TYPE(isolate->GetCurrentContext())                            \
                                <scratch space>:207:1: note: expanded from here
                                ToBoolean
                                /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2663:3: note: 'ToBoolean' has been explicitly marked deprecated here
                                 V8_DEPRECATED("ToBoolean can never throw. Use Local version.",
                                /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8config.h:328:29: note: expanded from macro 'V8_DEPRECATED'
                                 declarator __attribute__((deprecated(message)))
                                ../../nan/nan_converters_43_inl.h:40:1: warning: 'BooleanValue' is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
                                X(bool, Boolean)
                                ../../nan/nan_converters_43_inl.h:37:15: note: expanded from macro 'X'
                                 return val->NAME ## Value(isolate->GetCurrentContext());                     \
                                <scratch space>:214:1: note: expanded from here
                                BooleanValue
                                /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2701:3: note: 'BooleanValue' has been explicitly marked deprecated here
                                 V8_DEPRECATED("BooleanValue can never throw. Use Isolate version.",
                                In file included from ../../nan/nan.h:223:
                                In file included from ../../nan/nan_new.h:189:
                                ../../nan/nan_implementation_12_inl.h:356:37: error: too few arguments to function call, expected 2, have 1
                                 return v8::StringObject::New(value).As<v8::StringObject>();
                                /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:5531:3: note: 'New' declared here
                                 static Local<Value> New(Isolate* isolate, Local<String> value);
                                In file included from ../../nan/nan.h:2722:
                                ../../nan/nan_object_wrap.h:24:25: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
                                   assert(persistent().IsNearDeath());
                                /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/assert.h:93:25: note: expanded from macro 'assert'
                                   (__builtin_expect(!(e), 0) ? __assert_rtn(__func__, __FILE__, __LINE__, #e) : (void)0)
                                ../../nan/nan_object_wrap.h:127:26: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
                                   assert(wrap->handle_.IsNearDeath());
                                ../fsevents.cc:50:32: error: no template named 'Handle' in namespace 'v8'
                                   static void Initialize(v8::Handle<v8::Object> exports);
                                ../fsevents.cc:63:6: warning: field 'async_resource' will be initialized after field 'lockStarted' [-Wreorder]
                                  : async_resource("fsevents:FSEvents"), lockStarted(false) {
                                In file included from ../fsevents.cc:82:
                                ../src/constants.cc:89:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagNone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagNone));
                                /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:3498:3: note: 'Set' has been explicitly marked deprecated here
                                 V8_DEPRECATED("Use maybe version",
                                ../src/constants.cc:90:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMustScanSubDirs").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMustScanSubDirs));
                                ../src/constants.cc:91:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUserDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUserDropped));
                                ../src/constants.cc:92:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagKernelDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagKernelDropped));
                                ../src/constants.cc:93:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagEventIdsWrapped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagEventIdsWrapped));
                                ../src/constants.cc:94:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagHistoryDone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagHistoryDone));
                                ../src/constants.cc:95:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagRootChanged").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagRootChanged));
                                ../src/constants.cc:96:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMount));
                                ../src/constants.cc:97:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUnmount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUnmount));
                                ../src/constants.cc:98:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemCreated").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemCreated));
                                ../src/constants.cc:99:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRemoved").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRemoved));
                                ../src/constants.cc:100:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemInodeMetaMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemInodeMetaMod));
                                ../src/constants.cc:101:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRenamed").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRenamed));
                                ../src/constants.cc:102:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemModified").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemModified));
                                ../src/constants.cc:103:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemFinderInfoMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemFinderInfoMod));
                                ../src/constants.cc:104:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemChangeOwner").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemChangeOwner));
                                ../src/constants.cc:105:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemXattrMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemXattrMod));
                                ../src/constants.cc:106:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsFile").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsFile));
                                ../src/constants.cc:107:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsDir").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsDir));
                                ../src/constants.cc:108:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                 object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsSymlink").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsSymlink));
                                ../fsevents.cc:85:16: error: variable has incomplete type 'void'
                                void FSEvents::Initialize(v8::Handle<v8::Object> exports) {
                                ../fsevents.cc:85:31: error: no member named 'Handle' in namespace 'v8'
                                ../fsevents.cc:85:48: error: expected '(' for function-style cast or type construction
                                ../fsevents.cc:85:50: error: use of undeclared identifier 'exports'
                                ../fsevents.cc:85:58: error: expected ';' after top level declarator
                                23 warnings and 9 errors generated.
                                make: *** [Release/obj.target/fse/fsevents.o] Error 1
                                gyp ERR! build error
                                gyp ERR! stack Error: `make` failed with exit code: 2
                                gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                gyp ERR! System Darwin 19.4.0
                                gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node" "--module_name=fse" "--module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64" "--napi_version=5" "--node_abi_napi=napi"
                                gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
                                gyp ERR! node -v v12.16.3
                                gyp ERR! node-gyp -v v5.1.0
                                gyp ERR! not ok
                                node-pre-gyp ERR! build error
                                node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node --module_name=fse --module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64 --napi_version=5 --node_abi_napi=napi' (1)
                                node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                                node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                node-pre-gyp ERR! System Darwin 19.4.0
                                node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/bin/node-pre-gyp" "install" "--fallback-to-build"
                                node-pre-gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
                                node-pre-gyp ERR! node -v v12.16.3
                                node-pre-gyp ERR! node-pre-gyp -v v0.10.0
                                node-pre-gyp ERR! not ok
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                \e[92mDependencies installation Done!\e[90m
                                setting up initial config.js
                                \e[96mCheck plymouth installation ...\e[0m
                                \e[93mplymouth is not installed.\e[0m
                                Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
                                Do you want to disable the screen saver? (y/N)?n
                                \e[92mWe're ready! Run \e[1m\e[97mDISPLAY=:0 npm start\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
                                patrickhahn@Patricks-Mini ~ %
                                  @Stoffbeuteluwe so much fun…
                                  I put in a fix
                                  remove the MagicMirror folder and try again…
                                  I had not tried installer on mac since 2.10… sorry…
                                    @sdetweil MM install was without problems thank you…
                                    but pm2 say error but it works…
                                    Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                                    install and setup pm2
                                    Password:
                                    [PM2][ERROR] Init system not found
                                    /bin/sh: launchctl: command not found
                                    [PM2][ERROR] launchctl load -w /Users/patrickhahn/Library/LaunchAgents/pm2.patrickhahn.plist failed, see error above.
                                    [PM2] Spawning PM2 daemon with pm2_home=/Users/patrickhahn/.pm2
                                    [PM2] PM2 Successfully daemonized
                                    [PM2][WARN] Applications MagicMirror not running, starting...
                                    [PM2] App [MagicMirror] launched (1 instances)
                                    │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                    │ 0   │ MagicMirror    │ default     │ 2.11.0  │ fork    │ 4867     │ 0s     │ 0    │ online    │ 0%       │ 1.0mb    │ pat… │ enabled  │
                                    [PM2] Saving current process list...
                                    [PM2] Successfully saved in /Users/patrickhahn/.pm2/dump.pm2
                                    Do you want to disable the screen saver? (y/N)?y
                                    2020-05-22 14:37:06.275 defaults[5057:87330]
                                    The domain/default pair of (com.apple.screensaver, idleTime) does not exist
                                    bash: line 537: [: !=: unary operator expected
                                    \e[92mWe're ready! Run \e[1m\e[97mpm2 start MagicMirror\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
                                    patrickhahn@Mac-mini ~ %
                                      @Stoffbeuteluwe ok, on the screensaver can u show the results of this
                                      defaults -currentHost read com.apple.screensaver
                                      thanks… working on the pm2 issue
                                      what os level are u running on the mini?
                                        version10.15.4 (19E287)
                                          @Stoffbeuteluwe same here
                                            @Stoffbeuteluwe also can u do this
                                            which launchctl
                                            and this
                                            also the output of this
                                            pm2 startup
                                            thanks
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 10 / 11
