    MMM-Pollen?
    9 Posts 3 Posters 3.4k Views 3 Watching
    • C Offline
      cknight725
      Anyone know if this module still works?
      https://github.com/vincep5/MMM-Pollen
      It appears that pollen.com has shuttered their API or moved, modified, or something with it. I’m looking for a US-based Pollen data source similar…
      • C Offline
        cknight725
        Think I found a hint … pollen.com has started checking against user agent string, so the current code is inadequate.
        https://github.com/home-assistant/home-assistant/issues/15286
        • V Offline
          vinp Module Developer
          Oh no :( I’ll take a look at some point at my repository
          • V Offline
            It looks like it still works for me. Try doing a MM restart. Post your pm2 logs here or you can look at the Developer Toolbar from the browser to see if there are any interesting errors
            • K Offline
              kasperb @vinp
              @vinp I realize this is an old thread. Fair to assume the module is no longer working?
              • V Offline
                vinp Module Developer @kasperb
                @kasperb It is still working fine for me. I just tried it out.
                • K Offline
                  kasperb @vinp
                  @vinp Ok, thanks. Would you mind sharing your config? I copied the code from the instructions, but it’s stuck at ‘Loading…’.
                  • V Offline
                    @kasperb
                               module: "MMM-Pollen",
                               header: "Pollen Forecast",
                                   zip_code: "90210"
                    • K Offline
                      kasperb @vinp
                      @vinp Thanks… It worked after a reboot of the Pi. Much appreciated.
