    ELIFECYCLE error after fresh install
    elifecycle
    17 Posts 4 Posters 8.9k Views 3 Watching
      MrKnight230
      I encountered a problem that was already mentioned in this post:
      https://forum.magicmirror.builders/topic/7183/mm-not-loading-on-startup-or-manually
      But because this thread is unsolved and the last answer is more than 11 Months old I would like to try asking again for answers in this thread.
      I am currently setting my RasPi 3 B up from start.
      I downloaded the newest Raspbian with Desktop, installed and updated it and ran the one-line-command provided on the homepage.
      While installing I got 29 “vulnerabilities” which I solved with this “npm audit” and the recommended commands (somehow it threw these vulnerabilities stuff two times and as far as i understand the audit command only solved the vulnerabilities mentioned the second time).
      But now when trying to start the MagicMirror it tells me, there is an ELIFECYCLE error, probably not a problem with npm (see command prompt output).
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 1: run-start.sh: ����������������������������������������������������������������������������������������������������������������������������������������������: not found
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-04-14T07_20_07_609Z-debug.log
      As you might notice there is a log created, but somehow the files in this directory change every few seconds so I didn’t manage to attach it. If you could tell me how to get the log I’ll be happy to upload it in this thread!
      I already tried running “DISPLAY:=0 npm start” and “npm start” all with the same result. Furthermore I also tried “npm rebuild” without success.
      I am very thankful for every answer and appreciate your effort!
      Kind regards,
      MrKnight230
        MrKnight230
        Hi guys, I just wanted to say thank you to @bhepler and @sdetweil for trying to help me with this problem.
        In the end I just used a very old backup at first and updated it, which worked fine at first and yesterday I tried setting my RPi up from scratch again and it worked perfectly!
        I’m sorry for anybody who encounters the same error and tries finding answers here, sadly there doesn’t seem to be a perfect solution for this.
        MrKnight230
        • Z Offline
          Zwirbel
          I have the same error from a previously working MagicMirror after rebooting it. I did not change any code, just rebooted the RPi.
            sdetweil @MrKnight230
            @MrKnight230 can u show the output of npm -v
              sdetweil @Zwirbel
              @Zwirbel if you go the MagicMirror folder and do a pm2 stop, then npm start what happens?
                MrKnight230 @sdetweil
                @sdetweil The Version is 6.4.1
                  @MrKnight230 thx… are u doing this over vnc? also the MM has to be running in graphical mode, unless u are running server only… (DISPLAY 0 will not exist if in VNC or text mode)
                    The RasPi is connected via HDMI to a Display and I’m using VNC to configure it. I had a previous install where everything worked with pm2 and manually using the command “npm start”.
                      @MrKnight230 sorry, do not know… there were lots of code changes by modules MM uses and have no control over.
                      I cannot recreate this over ssh…
                      my npm is version 6.9.0
                      you might try
                      npm install -g npm
                        @sdetweil Thanks for the suggestion, it successfully installed version 6.9.0 but sadly didn’t solve or even change anything about the problem.
                          @MrKnight230 ok, i can only think that the vnc start is not working now…
                            @sdetweil Well I deactivated VNC, restarted and plugged my keyboard in the RasPi and this too didn’t change anything sadly.
                              @MrKnight230 ok, and u did the DISPLAY=:0
                                @sdetweil I actually didn’t but the result stays the same with “DISPLAY=:0”
                                  @MrKnight230 and after u did the git pull of the new version, you did npm install in the MM folder and all modules with a package.json file, right?
                                    @sdetweil I did run npm install again now and the output looks like this:
                                    pi@raspberrypi:~/MagicMirror $ npm install
                                    > magicmirror@2.7.1 install /home/pi/MagicMirror
                                    > cd vendor && npm install
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    audited 219 packages in 10.29s
                                    found 5 vulnerabilities (4 low, 1 high)
                                      run `npm audit fix` to fix them, or `npm audit` for details
                                    > magicmirror@2.7.1 postinstall /home/pi/MagicMirror
                                    > sh installers/postinstall/postinstall.sh && npm run install-fonts
                                    MagicMirror installation successful!
                                    > magicmirror@2.7.1 install-fonts /home/pi/MagicMirror
                                    > cd fonts && npm install
                                    audited 1 package in 1.092s
                                    found 0 vulnerabilities
                                    npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                                    npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                                    added 7 packages from 10 contributors, updated 6 packages and audited 3468 packages in 63.499s
                                    But it again didn’t change anything.
                                      bhepler Module Developer @MrKnight230
                                      @MrKnight230 - The good news is that the npm install completed successfully. Hmm.
                                      Have you tried running Magic Mirror in server only mode and then hitting your mirror with a web browser?
                                      IMHO, I think the “fix vulnerabilities” feature of npm is causing more trouble than it is worth.
                                        MrKnight230
                                        MrKnight230
