    MMM-iFrame or MMM-iFrame-Ping show nothing since last update
    7 Posts 4 Posters 3.2k Views 4 Watching
    • B
      BluP Project Sponsor
      Hi everybody,
      Just recently updated MM from 2.4.0 to 2.7.1 including all modules.
      Unfortunately had issues with MMM-Remote-Control first but used the fixes described on Github.
      But both MMM-iFrame or MMM-iFrame-Ping don’t show anything.
      I used MMM-iFrame to show a live video stream from my frontdoor using another Pi with Motion and using a curl command to show the iFrame on the MM when movement was detected and hide it after a while. That worked perfectly. I also could use this via homekit and ask Siri to turn on the Frontdoor Cam for example.
      I can see via http://MyMMIP:8080/remote?action=MODULE_DATA that the state of “hidden” changes between “true” and “false” when I use MMM-Remote-Control from my Mac or iPhone or when i use the buttons (show/hide Module iFrame)
      But it shows nothing…
      Anybody here who has an iFrame up and running with MM 2.7.1.
      My other modules:
      calendar_monthly
      MMM-Carousel
      MMM-iFrame-Ping or MMM-iFrame
      MMM-RandomPhoto or MMM-BackgroundSlideshow
      MMM-Tado
      MMM-DWD-WarnWeather
      MMM-ModuleScheduler
      MMM-Remote-Control
      MMM-Tools
      MMM-EasyPix
      MMM-MyCommute
      MMM-Snow
      MMM-Wunderlist
      MMM-Buttons
      MMM-NetworkScanner
      MMM-syslog
      netatmo
      Thanks,
      • B
        BluP Project Sponsor @BluP
        @BluP: Got additional information from the console:
        update3
        MMM-iFrame.js:26
        Resource interpreted as Document but transferred with MIME type multipart/x-mixed-replace: “”.
        main.js:210 Resource interpreted as Document but transferred with MIME type multipart/x-mixed-replace: “http://192.168.178.8:8081/”.
        @alberttwong: can you give me a hint what needs to be adjusted?
        @cowboysdude : I’ve searched the forum and also github and saw that yiou once had issues with iframe as well…any hints from your side?
        Thx, Peter
        cowboysdudeC S 2 Replies Last reply Reply Quote 0
        • cowboysdudeC
          cowboysdude Module Developer @BluP
          @BluP Don’t really have any suggestions other then play with the settings.
            sdetweil @BluP
            @BluP open the developers window, ctrl-shift-i, then select the console tab, and scroll up to see any errors, red text
            B 2 Replies Last reply Reply Quote 0
            • B
              Binog
              I do get this:
              [Error] Refused to execute http://ip:8080/modules/iFrameReload//iFrameReload.js as script because "X-Content-Type: nosniff" was given and its Content-Type is not a script MIME type.
              Error on loading script: – "modules/iFrameReload//iFrameReload.js"
              onerror — loader.js:190
              Refused to display 'https://www.google.com/maps/' in a frame because it set 'X-Frame-Options' to 'SAMEORIGIN'.
              What can I do about this?
              • B
                BluP Project Sponsor @sdetweil
                @sdetweil Hi Sam, I tried that and the I got warnings about MMM-iFrame:
                main.js:210 Resource interpreted as Document but transferred with MIME type multipart/x-mixed-replace: "http://192.168.178.8:8081/".
                updateModuleContent	@	main.js:210
                (anonymous)	@	main.js:139
                updateDomWithContent	@	main.js:137
                (anonymous)	@	main.js:119
                Promise.then (async)
                (anonymous)	@	main.js:118
                updateDom	@	main.js:109
                updateDom	@	main.js:518
                updateDom	@	module.js:358
                (anonymous)	@	MMM-iFrame.js:25
                The url is my other RasPi running Monitor displaying a video from my frontdoor.
                As I stated in my 1st post, all was good since I upgraded to 2.7.1… :-(
                Any more hints?
                Thx, Peter
                • B
                  I finally got it working again!:thumbs_up:
                  I did a full fresh installation on a new SD card with complete latest Raspian and new MM and all the modules I used before…and still the same behavior: MMM-IFrame showed nothing and I got the same warnings as mentioned below.
                  Then I tried MMM-SmartWebDisplay by @AgP42 which finally displays my video stream again. (BTW: This also works with other URLs as described in the documentation)
                  Many thanks for this module.:clapping_hands:
                  For all having issues with MMM-iFrame, MMM-IFrame-Ping etc., try MMM-SmartWebDisplay.
                  Don’t forget to do a NPM install in the module folder once the module is cloned.
                  Thanks, Peter
