    Newsfeed is not loading
    2 Posts 2 Posters 3.8k Views 2 Watching
    • H
      Himbeerkuchen
      Hello!
      I’m doing my first steps on the Magic Mirror project and I was able to get run everything but not the newsfeed.
      I changed the script like this:
      module: ‘newsfeed’,
      position: ‘bottom_bar’,
      feeds: [
      title: “news.orf.at”,
      url: “http://rss.orf.at/news.xml”
      showSourceTitle: true,
      showPublishDate: true
      The newsfeed ist not loading anything and in the terminal I get following:
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Starting module: newsfeed
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://rss.orf.at/news.xml - Interval: 300000
      Whoops! There was an uncaught exception…
      TypeError: parser.close is not a function
      at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
      at emitOne (events.js:96:13)
      at SAXStream.emit (events.js:188:7)
      at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
      at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
      at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
      at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
      at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1318:13)
      at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
      at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
      Can anybody pleayse tell me why it is not working?
      Thank you very much for your help!
      • B
        bhepler Module Developer
        I copied your module configuration and found a couple things. It looks like you may be having a character set issue. It may just be an artifact of the copy & paste. But here’s what I found:
        1. You need to use the single quote character around your text values. module: 'newsfeed. I’m not sure what character is in there, but my system didn’t like it.
        2. The showSourceTitle and showPublishDate variables are not part of the config: {...} section, so the closed curly brace (}) needs to be moved up 2 lines to just after the closed bracket (]).
        3. I think that once you make these changes, you’ll have to bounce the magic mirror process to get the content to show up. I was able to see the module, and received no errors, but the content didn’t load.
