    Finding module with high external traffic
    9 Posts 3 Posters 1.9k Views 3 Watching
      mmmmh Project Sponsor
      The modules I use all rely on local data sources. I run my instance in server-only mode. Still, I see unexpected traffic to a google-hosted IP address. How can I find the culprit (and stop it)?
      • ? Offline
        A Former User @mmmmh
        @mmmmh Which modules are you using?
          sdetweil @Guest
          @Sean if you dnslookup that ip address, does it have a name associated?
            mmmmh Project Sponsor @Guest
            @Sean I think I found the “culprit”, it may be the Spotify module’s polling. I just increased the interval and will see if the traffic decreases.
              mmmmh Project Sponsor @sdetweil
              @sdetweil the IP resolves to a generic Google host, currently 53.224.186.35.bc.googleusercontent.com - I think it is used by Spotify.
              • ? Offline
                @mmmmh Yes, it retrieves requests per 1~2 seconds. Unfortunately Spotify Web API doesn’t support push mechanism to get status updated. So it needs pooling. I recommend 2000 ms or more frequency to update current playback if you don’t care.
                  @Sean I think I read somewhere that callback addresses could be provided (perhaps I misread this). If I have a DynDNS-backed FQD host and forwarded port I can provide, would this stop the polling requirement?
                  • ? Offline
                    @mmmmh I don’t think so. To update current playback info (The playing status, playing time,…) on real time, This module has to call Spotify Web APIs frequently.
                      @Sean I checked again, you are right, polling is the only option. Thanks for your cool module!
