    How to change the path of a picture in magicmirror , using MMM-imageSlideshow
    17 Posts 2 Posters 6.4k Views 2 Watching
    • E Offline
      emrhssla
      I’m using three modules.
      MMM-Testpython (This is the module I’m developing.)
      MMM-imageSlideshow
      MMM-Modulebar1
      When I click the click button implemented in the Testpython module code, I want to change the path of the file where the picture is stored. So I want to show you a picture of a different path.
      modules/MMM-Testpython/nothing ->modules/MMM-Testpython/before
      I implemented it using “sendnotification” in MMM-Testpython, “notificationreceived” in MMM-imageSlideshow.
      It was confirmed that the output was successful on the console window.
      before click
      after click
      However, the picture does not change on screen.
      The code is as follows.
      MMM-imageSlideshow
      I’ve just modified the underline for @@@@@@@@@@@@@@@
      /* global Module */
      /* MMM-ImageSlideshow.js
       * Magic Mirror
       * Module: MMM-ImageSlideshow
       * Magic Mirror By Michael Teeuw http://michaelteeuw.nl
       * MIT Licensed.
       * Module MMM-ImageSlideshow By Adam Moses http://adammoses.com
       * MIT Licensed.
      Module.register("MMM-ImageSlideshow", {
      	// Default module config.
      	defaults: {
              // an array of strings, each is a path to a directory with images
              imagePaths: [ 'modules/MMM-Testpython/nothing' ],
              // the speed at which to switch between images, in milliseconds
      		slideshowSpeed: 10 * 1000,
              // if zero do nothing, otherwise set width to a pixel value
              fixedImageWidth: 0,
              // if zero do nothing, otherwise set height to a pixel value
              fixedImageHeight: 0,
              // if true randomize image order, otherwise do alphabetical
              randomizeImageOrder: false,
              // if true combine all images in all the paths
              // if false each path with be viewed seperately in the order listed
              treatAllPathsAsOne: false,
              // if true, all images will be made grayscale, otherwise as they are
              makeImagesGrayscale: false,
              // list of valid file extensions, seperated by commas
              validImageFileExtensions: 'bmp,jpg,gif,png',
      		// a delay timer after all images have been shown, to wait to restart (in ms)
      		delayUntilRestart: 0,
          // load function
      	start: function () {
              // add identifier to the config
              this.config.identifier = this.identifier;
              // ensure file extensions are lower case
              this.config.validImageFileExtensions = this.config.validImageFileExtensions.toLowerCase();
              // set no error
      		this.errorMessage = null;
              if (this.config.imagePaths.length == 0) {
                  this.errorMessage = "MMM-ImageSlideshow: Missing required parameter."
              else {
                  // create an empty image list
                  this.imageList = [];
                  // set beginning image index to -1, as it will auto increment on start
                  this.imageIndex = -1;
                  // ask helper function to get the image list
                  this.sendSocketNotification('IMAGESLIDESHOW_REGISTER_CONFIG', this.config);
      			// do one update time to clear the html
      			this.updateDom();
      			// set a blank timer
      			this.interval = null;
      	// Define required scripts.
      	getStyles: function() {
              // the css contains the make grayscale code
      		return ["imageslideshow.css"];
      	// the socket handler
      		// if an update was received
      		if (notification === "IMAGESLIDESHOW_FILELIST") {
      			// check this is for this module based on the woeid
      			if (payload.identifier === this.identifier)
      				// set the image list
      				this.imageList = payload.imageList;
                      // if image list actually contains images
                      // set loaded flag to true and update dom
                      if (this.imageList.length > 0) {
                          this.loaded = true;
                          this.updateDom();
      					// set the timer schedule to the slideshow speed
      					var self = this;
      					this.interval = setInterval(function() {
      						self.updateDom();
      						}, this.config.slideshowSpeed);
      	// Override dom generator.
      	getDom: function () {
              // if an error, say so (currently no errors can occur)
              if (this.errorMessage != null) {
                  wrapper.innerHTML = this.errorMessage;
              // if no errors
              else {
                  // if the image list has been loaded
                  if (this.loaded === true) {
      				// if was delayed until restart, reset index reset timer
      				if (this.imageIndex == -2) {
      					clearInterval(this.interval);
      					var self = this;
      						self.updateDom(0);
                      // iterate the image list index
                      this.imageIndex += 1;
      				// set flag to show stuff
      				var showSomething = true;
                      // if exceeded the size of the list, go back to zero
                      if (this.imageIndex == this.imageList.length) {
      					// if delay after last image, set to wait
      					if (this.config.delayUntilRestart > 0) {
      						this.imageIndex = -2;
      						wrapper.innerHTML = " ";
      						showSomething = false;
      						var self = this;
      							self.updateDom(0);
      							}, this.config.delayUntilRestart);
      					// if not reset index
      					else
      						this.imageIndex = 0;
      				if (showSomething) {
      					// create the image dom bit
      					var image = document.createElement("img");
      					// if set to make grayscale, flag the class set in the .css file
      					if (this.config.makeImagesGrayscale)
      						image.className = "desaturate";
      					// create an empty string
      					var styleString = '';
      					// if width or height or non-zero, add them to the style string
      					if (this.config.fixedImageWidth != 0)
      						styleString += 'width:' + this.config.fixedImageWidth + 'px;';
      					if (this.config.fixedImageHeight != 0)
      						styleString += 'height:' + this.config.fixedImageHeight + 'px;';
      					// if style string has antyhing, set it
      					if (styleString != '')
      						image.style = styleString;
      					// set the image location
      					image.src = this.imageList[this.imageIndex];
      					// ad the image to the dom
      					wrapper.appendChild(image);
                  else {
                      // if no data loaded yet, empty html
              // return the dom
      		return wrapper;
      	// @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ my code @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
      	notificationReceived: function(notification, payload) {
      		Log.info(this.name + " - received notification: " + notification);
      		if(notification === "BEFORE"){
      			console.log("this payload : "+payload)
      			this.config.imagePaths=payload
      			var self = this;
      			self.updateDom();
      			console.log("this config config payload : "+this.config.imagePaths)
      MMM-Testpython
      var Testpythons;
      Module.register("MMM-Testpython", {
          defaults: {},
          start: function (){
              Testpythons = this;
        getDom: function() {
          var element = document.createElement("div")
          element.className = "myContent"
          element.id="divid"
          element.innerHTML = "Hello, World!!! " + this.config.foo
          var subElement = document.createElement("p")
          subElement.innerHTML = "Click"
          subElement.id = "clickid"
          element.appendChild(subElement)
          return element
        notificationReceived: function(notification, payload, sender) {
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
            var elem = document.getElementById("clickid")
            elem.addEventListener("click", () => {
              // send!!
              Testpythons.sendNotification('BEFORE','modules/MMM-Testpython/before');
              elem.innerHTML = "click success"
              break
        sdetweil @emrhssla
        @emrhssla i think this is a caching problem… the ‘file’ was already loaded…
        see this discussion about adding a string to the end of the image filename to make it ‘unique’
        thus not reading from cache
        https://stackoverflow.com/questions/728616/disable-cache-for-some-images
        however, this will add a new image to be cached… eventually growing maybe beyond memory limits…
        another way is to disable caching in electron
        in MagicMirror/js/electron.js
        add this line
        function createWindow() {
            app.commandLine.appendSwitch('--disable-http-cache');  //< -------- added
        	var electronOptionsDefaults = {
          sdetweil @emrhssla
          @emrhssla because ImageSlideshow is using hard coded paths
          imagePaths: [ ‘modules/MMM-Testpython/nothing’ ],
          U must add the before path to the list
          • E Offline
            emrhssla @sdetweil
            There’s no other way.
            Then there’s one more question. Originally, MMM-Testpython is a module that uses python files to capture pictures.
            I tried to show the captured pictures using MMM-imageSlideshow.
            To sum up, what I want is:
            1.Run the magic mirror.
            2.MMM-imageSlideShow runs to show the pictures in the folder
            3.Use MMM-Testpython to capture it with a webcam.
            4.Replace original photos by covering them.
            ------I’ve been successful so far----
            5. MMM-imageSlideshow module has been updated to show only captured pictures (failed)
            So what I’m wondering is if I can update MMM-imageSlideshow in the Magic Mirror.
            Updatedom() will not be renewed.
              sdetweil @emrhssla
              @emrhssla what do u mean by update ImageSlideshow?
              Change it’s paths dynamically?
              I dont think so
              • E Offline
                emrhssla @sdetweil
                not about path update
                about replacing a picture with an overwritten one dynamically.
                  sdetweil @emrhssla
                  @emrhssla should be able to without problem… either write code to do it… or launch a shell cp command (copy)
                    sdetweil
                    also, MMM-ImageSlideshow only gets the file list once… then reshows it over and over…
                    MMM-ImagesPhotos refreshes the list every 60 seconds… ( getInterval: 60000)
                    • E Offline
                      emrhssla
                      MMM-Testpython.js
                      var Testpythons;
                          defaults: {},
                          start: function (){
                              Testpythons = this;
                          element.id="divid"
                          return element
                              Testpythons.sendSocketNotification("TEST")
                              console.log(" click success !")
                              break
                            case "AFTERCLICK":
                              console.log("Socket recevied payload : "+payload)
                              var elemk = document.getElementById("clickid")
                              Testpythons.sendNotification('SHOWCHANGEDIMAGE');
                              elemk.innerHTML = payload
                              break
                      node_helper.js(in MMM-Testpython)
                      var NodeHelper = require("node_helper");
                      var {PythonShell} = require('python-shell');
                      var socketTestpython;
                        start: function() {
                          socketTestpython=this;
                          console.log(this.name+"node_helper started")
                            case "TEST":
                              console.log("notification : " + notification)
                      	    PythonShell.run('/home/pi/Desktop/BeautyMirror/modules/MMM-Testpython/before.py', null, function (err, result) {
                                  if (err) throw err;
                                  console.log(result);
                                  socketTestpython.sendSocketNotification("AFTERCLICK",result);
                              break
                      I added only the following code from the original module code.
                      		if(notification === "DOM_OBJECTS_CREATED"){
                      			this.hide()
                      		if(notification === "SHOWCHANGEDIMAGE"){
                      			var self = this;
                      			self.updateDom();
                      			self.show();
                      console is success…
                      image before capture
                      capture image
                      after caputure
                      • E Offline
                        emrhssla @emrhssla
                        not changed in screen omg…
                          sdetweil @emrhssla
                          @emrhssla if u stop mirror and restart, does the new image appear? (as u overlaid the old one)…
                          if not, then your overlay function doesn’t work…
                            sdetweil
                            and another test, open a browser on mm, then use the full file url to the new image file
                            file:///home/pi/MagicMirror/modules/MMM-ImageSlideshow/…
                            and see if the pic opens
                            • E Offline
                              emrhssla @sdetweil
                              Clicking makes the capture and overwrite the file successful in the process where the magic mirror is run. But it doesn’t appear on the screen.
                              When the magic mirror is turned off and restarted, a new image will appear successfully.
                              I think the code is working properly, but the MMM-imageSlideshow module is not being renewed.
                              • E Offline
                                emrhssla @sdetweil
                                Are you saying to run chrome and put fil://~ in url?
                                  sdetweil @emrhssla
                                  @emrhssla yes, just adding another way to verify that the file was changed… u reported it is ok…
                                  • E Offline
                                    emrhssla @sdetweil
                                    @sdetweil When I click Refresh in Chrome, a picture that has been successfully changed appears.
                                    Is there any way to restart a specific module?
                                      sdetweil @emrhssla
                                      add this line
                                      • E Offline
                                        emrhssla @sdetweil
                                        @sdetweil thank U!!
