Error with Config.
I have been trying to work out what’s wrong with this dev build.
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'US Holidays', position: 'top_left', config: { calendars: [ { symbol: 'calendar-check-o ', url: '-------s' } ] } }, { module: 'MMM-Traffic', position: 'top_center', classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name config: { api_key: '---', mode: 'driving', origin: '------', destination: '-----', arrival_time: '0800', //optional, but needs to be in 24 hour time if used. route_name: 'Home to Work', changeColor: true, showGreen: false, limitYellow: 5, //Greater than 5% of journey time due to traffic limitRed: 20, //Greater than 20% of journey time due to traffic traffic_model: 'pessimistic', interval: 120000 //2 minutes }, }, { module: 'currentweather', position: 'top_right', config: { location: 'New York', locationID: '', //ID from http://www.openweathermap.org appid: '-----' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'New York', locationID: '5128581', //ID from http://www.openweathermap.org appid: '----' } }, { module: 'MMM-SystemStats', position: 'bottom_left', // This can be any of the regions. classes: 'small dimmed', // Add your own styling. Optional. config: { updateInterval: 10000, animationSpeed: 0, //header: 'System Stats', // This is optional }, ], }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;} -
@jtyle6 said in Error with Config.:
module: ‘MMM-SystemStats’,
position: ‘bottom_left’, // This can be any of the regions.
classes: ‘small dimmed’, // Add your own styling. Optional.
animationSpeed: 0,
//header: ‘System Stats’, // This is optional
you missed a
}before closing all the modules with]and closing module systemstats with}animationSpeed: 0, //header: 'System Stats', // This is optional } }, ], -
Fixed from a backup. I really need to learn how to code.
