    MMM-GoogleAssistant autostart
    46 Posts 3 Posters 27.7k Views 3 Watching
    • P Offline
      poopyurinal
      I have been trying without success to get the MMM-GoogleAssistant module to autostart upon boot. I have followed so many tutorials down the rabbit hole I am not sure where I have ended up. I know that to start the module successfully, I can enter the following 3 commands:
      source env/bin/activate
      cd ~/MagicMirror/modules/MMM-GoogleAssistant/pi
      python3 assistant.py
      Every method I have tried to do this upon boot has failed. Can anyone provide a simple tutorial on how to do this via, well, ANY method? I am beyond newbie in Linux, but still very much a beginner. If you need more details about my assistant.py, please let me know. I am not particular to any one method as long as it works.
      Thanks!
        sdetweil
        what is the reported problem? and where?
        • P Offline
          poopyurinal
          I don’t get a reported problem (or don’t know where to look). I just don’t have an active module upon boot. Where can I look for a reported problem?
            sdetweil
            starting a pgm at boot
            https://timleland.com/how-to-run-a-linux-program-on-startup/
            you might need two? on the py and one the mirror app?
              sdetweil @poopyurinal
              @poopyurinal so, does mirror app start? but assistant doesn’t work ? are you using pm2? to control Mirror autostart?
                sdetweil
                auto install script sets up a pm2 module to start mirror app
                • P Offline
                  poopyurinal
                  yes, the mirror app starts flawlessly with all installed modules. The assistant icon appears on the mirror, but is not activated by “Ok google” unless I type the commands in my OP. I believe pm2 is controlling the Mirror autostart.
                    @poopyurinal ok, but if yoiu start it manually does it work?
                    pm2 stop MagicMirror
                    open a terminal window (ctrl-alt-t)
                    cd MagicMirror
                    npm start
                    does it all work?
                    I don’t know assistant.py I assume it runs in the background… and somehow talks to the module…
                      sdetweil
                      and with mirror running on boot, press ctrl-shit-i to open the developers window, and select the console tab, and scroll up to find any module errors
                      there is also a pm2 command to show its log… (I don’t use pm2 myself).
                        @poopyurinal said in MMM-GoogleAssistant autostart:
                        you are not starting the module… you are starting a background application
                        that is included in the module folder
                        the ‘module’ only runs inside the MagicMirror environment
                        so, you need to create a command that does the startup…
                        start the py and then start MM
                        and then automate that
                        if u stop MM manually and restart it (without doing the assistant.py step) do the GA work thru mirror as u expect?
                        • P Offline
                          poopyurinal
                          pm2 stop MagicMirror gives me:
                          [PM2][ERROR] Process MagicMirror not found
                          │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │
                          │ mm │ 0 │ fork │ online │ 1 │ 0% │ 2.5 MB │
                          Use pm2 show <id|name> to get more details about an app
                          Any thoughts? The MagicMirror is running. If I stop it by hitting Alt and closing it via the menu bar, it automatically restarts.
                            @poopyurinal pm2 list
                            • P Offline
                              poopyurinal
                              pm2 list
                                @poopyurinal pm2 stop mm
                                • P Offline
                                  poopyurinal
                                  pm2 stop mm
                                  [PM2] Applying action stopProcessId on app [mm](ids: 0)
                                  [PM2] mm ✓
                                  │ mm │ 0 │ fork │ stopped │ 1 │ 0% │ 0 B │
                                  Sorry, limited by new user restriction of one post every 120 seconds
                                    @poopyurinal cool now follow the link i gave about creating a service that will autostart and make it start the assitant.py
                                    I don’t understand why the MMM-GoogleAssistant module doesn’t do this… it would be so easy…
                                      sdetweil
                                      in the link it asks for ‘your service name’ make that GoogleAssistant
                                      the command is ‘/home/pi/MagicMirror/modulesMMM-GoogleAssistant/python3 assistant.py’
                                        sdetweil
                                        once u create the service… make sure assistant.py is not running already
                                        ps -ef | grep assistant
                                        the 1st number on the output is the process id
                                        pi xxxx yyyy etc…
                                        then
                                        sudo kill -9 xxxx
                                        then do
                                        sudo systemctl start GoogleAssistant
                                        then
                                        to insure assistant is running
                                        then start mirror manually with npm start
                                        if all is good, reboot
                                        service will start the assistant.py script
                                        and pm2 will start mirror app
                                        • P Offline
                                          poopyurinal
                                          Many thanks Sam! I’ll need to take a look at your suggestions tomorrow. I appreciate the quick (immediate!) help.
                                            @poopyurinal no problem… let us know either way
                                            i use the assistantmk2 module… don’t need that py file
                                            • 1 / 3
