    Node Install Issues
    5 Posts 3 Posters 1.8k Views 3 Watching
    • N Offline
      Natacha
      I was able to get MM setup but then when I upgraded Node I’m now receiving the following error when doing
      sudo npm start
      Here is the error that is returned after I run this via Remote Desktop terminal
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ sudo npm start
      magicmirror@2.7.1 start /home/pi/MagicMirror
      sh run-start.sh
      No protocol specified
      (electron:4538): Gtk-WARNING **: cannot open display: :10.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.7.1 start: sh run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      npm ERR! /root/.npm/_logs/2019-05-17T05_48_06_943Z-debug.log
      Here is the log info:
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@6.9.0
      3 info using node@v10.15.3
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
      6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
      7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-$
      9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
      12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:3$
      13 verbose stack at EventEmitter.emit (events.js:189:13)
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.$
      13 verbose stack at ChildProcess.emit (events.js:189:13)
      13 verbose stack at maybeClose (internal/child_process.js:970:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.7.1
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.14.98-v7+
      17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
      18 verbose node v10.15.3
      19 verbose npm v6.9.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.7.1 start: sh run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.7.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Any help is appreciated. Thank you!
      -newbie raspberry pi girl / natacha
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @Natacha
        @Natacha now that u upgraded node, you have to go back and redo
        npm install
        in the MM folder and all module folders if they have a package.json file
          Mykle1 Project Sponsor Module Developer @Natacha
          @Natacha said in Node Install Issues:
          sudo npm start
          You should not be using sudo npm start
          Simply, npm start in your MagicMirror directory. :-)
          Follow @sdetweil instructions first.
            sdetweil @Mykle1
            @Mykle1 good catch… didn’t see sudo
              :thumbsup:
