    MMM-GoogleCast
    14 Posts 10 Posters 8.0k Views 9 Watching
    • F Offline
      ferferga
      Show what’s being played in your Google Cast device right in your mirror.
      Screenshot
      Github repository
      StoffbeuteluweS 1 Reply Last reply Reply Quote 4
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @ferferga
        @ferferga Hi…is Apple Music possible???
        • WasupDudeW Offline
          WasupDude Banned
          wow, thank you for information
          • V Offline
            veego
            Hey there,
            I hope that someone can support me.
            How can I add another chromecast device id after I have already ran the initial install? If I try to install again, nothing happens. Just looking to add another chromecast (in another module instance) since the initial install.
            I would greatly appreciate it if you could give me the terminal line command.
            Love this module so much.
            • T Offline
              teitlebot @veego
              @veego you just repeat the code in config file twice with different ideas. no need to reinstall anything.
                Is there a module does the same with Alexa echo device?
                  sturag
                  Is it possible to remove the speaker icon and volumebar?
                    broberg Project Sponsor @sturag
                    @sturag said in MMM-GoogleCast:
                    in custom.css add :
                    .MMM-GoogleCast .volumeDiv {visibility:hidden}
                    .MMM-GoogleCast .volumeIcon {visibility:hidden}
                    S T 2 Replies Last reply Reply Quote 0
                      sturag @broberg
                      @broberg Thanks!
                      Added:
                      .MMM-GoogleCast .deviceStatus {visibility:hidden}
                      to get ridd of the play icon :)
                      • T Offline
                        teitlebot @broberg
                        @broberg Is it possible to lay out all the speakers side by side?
                        great module btw
                          meckhart
                          I have installed this module but I can’t get it to display my Chromecasts. All I get are spinning loading icons. I ran the GetChromecasts.py script and put my device IDs in the config but I can’t seem to get the info to load. Any ideas?
                            meckhart @meckhart
                            @meckhart I just installed the newest update and everything is working. Not sure what was changed but it seemed to fix whatever issues I was having.
                            • P Offline
                              perco08
                              Hello,
                              First of all, thank you very much for this module ! I have discovered MM a couple of weeks and cannot stop playing with it! I use it not as a photo frame.
                              I have several google mini, etc at home and managed to install multiple instances of the module on my MM (I have 1 page of the mirror showing 3 different google cast devices and it works perfectly).
                              I am trying to have MMM-Googlecast showing a minimum of info for a specific device: I just would like to show the type of media (Spotify, etc.), the titel of the song and the artist, with the icons and nothing else (no album cover, no volume icon, etc.). I tried to play with the css (I am a newbee and do not understand CSS at all…) and with custom css, using Visibility:hidden but I am lost with the different possibilities and cannot manage to get exactly what I want.
                              Do you think it’s feasible?
                              Many thanks in advance
                                agentscript
                                Dosent seem to work with Google Mini. I ask Google to play a song and nothing shows up.
                                Infact it doesn’t recoganise Google Mini at all.
