    MMM-YouTube
    64 Posts 15 Posters 30.1k Views 16 Watching
    • ? Offline
      A Former User @rafaelcota
      @rafaelcota
      updated. try again after update.
      you can play playlist like this; /yl PL55713C70BA91BD6E
      rafaelcotaR 1 Reply Last reply Reply Quote 0
      • rafaelcotaR Offline
        rafaelcota @Guest
        @Sean Thank you very much
          rafaelcota @Guest
          Hi @Sean,
          I did the git pull and then try it, but I can’t seem to make it do anything, even the /yt commands that already were working.
          All I can see is this message in the console:
          [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number
          And nothing happens in the mirror screen, not with /yt or /yl. If I do a /yc getVolume it gives me the right number, so I get the module is loaded.
          My config is:
          disabled: false,
          module: “MMM-YouTube”,
          position: “fullscreen_below”,
          verbose:true,
          Any ideas where I should look?
          Thanks in advanced
          • ? Offline
            @rafaelcota
            Well, with my test, there is no problem to execute at all.
            If you see [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number, your telegram messages are received properly.
            Check if you have a front-end error. (With npm start dev or Ctrl+i)
            Or you can check by removing all other modules from config except MMM-YouTube and MMM-TelegramBot.
              rafaelcota @Guest
              @Sean Thank you again,
              Just as data, could be useful or not, I can play just some videos; with only TelegramBot and MMM-YouTube modules loaded or with all I got, it doesn’t matter:
              PLAY OK
              /yt https://youtu.be/5KJiO8W9iyg
              DOESN’T PLAY (the mirror does nothing at all)
              /yt https://youtu.be/y83x7MgzWOA
              /yl PLDIoUOhQQPlXr63I_vwF9GD8sAKh77dWU
              • ? Offline
                @rafaelcota said in MMM-YouTube:
                Hmmm. with my test, it works well.
                With verbose:true option, in dev-console you can see what’s going on. Try and tell me what’s significantly suspicious?
                  rafaelcota @Guest
                  @Sean The messages are now clear, “Not allowed By Owner”
                  I guess there’s nothing I can do but finding videos that are allowed to be played outside YouTube.
                  Thank’s again
                    mosheva
                    I’m wondering if it possible to run the module but to not display the video?
                    I would like to have just the audio.
                    Thanks.
                    • ? Offline
                      A Former User @mosheva
                      @mosheva
                      Hmmmm… difficult question. Maybe with CSS, it could be but I haven’t tested.
                        mosheva @Guest
                        @Sean @Sean Thanks, is there a way to make the youtube screen 1px by 1px? :)
                        the smaller option in the code is “small”…
                        • 6
                        • 7
                        • 5 / 7
