    MMM-YouTube
    64 Posts 15 Posters 36.8k Views 16 Watching
      sdetweil @juantata
      @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
      edit ~/MagicMirror/js/electron.js
      make sure the line below is present
      // Keep a global reference of the window object, if you don't, the window will
      // be closed automatically when the JavaScript object is garbage collected.
      let mainWindow;
      function createWindow() {
      	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
      if not, add it then stop and restart MagicMirror
        juantata @sdetweil
        the video finds him
        The electron.js file
          sdetweil @juantata
          @juantata great info… but then not the problem…
          • ? Offline
            A Former User @juantata
            @juantata said in MMM-YouTube:
            To call the youtube module I say:
            Ok google + singer’s name + song title, and the result is this
            I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
            J 3 Replies Last reply Reply Quote 0
              juantata @Guest
              This post is deleted!
                juantata @Guest
                @Sean
                How do you use the module?
                  juantata @juantata
                  @juantata
                  Wrongly asked the question
                    juantata @Guest
                    @Sean
                    How do you make the module work?
                      sdetweil @juantata
                      @juantata you need some other module to send it a command (notification)
                      see the doc
                      https://github.com/eouia/MMM-YouTube
                        juantata @sdetweil
                        MMM-TelegramBot?
                        If this is, I thought it was optional.
                          sdetweil @juantata
                          @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
                          depends on what you want to do…
                          J 2 Replies Last reply Reply Quote 0
                            juantata @sdetweil
                            All I want is to say
                            for example:
                            “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                              juantata @sdetweil
                              If that were not possible, could you tell me, if it is not a problem, the configuration of MMM-TelegramBot?
                                sdetweil @juantata
                                MMM-TelegramBot
                                see the readme https://github.com/eouia/MMM-TelegramBot
                                there are three pieces to your desired result
                                something to hear ‘Ok Google’ (the hotword, as the mic is listening ALL the time, so only want it to trigger after a wakeup/hotword), just like real devices, MMM-Hotword
                                something to decode your voice and return words and maybe act, MMM-AssistantMk2 does this for google…
                                and something to play from youtube… which it looks like MMM-Youtube does…
                                I use MMM-Hotword and MMM-AssistantMk2 to answer questions and put mirror to sleep/wake up.
                                i don’t play videos or music on the mirror
                                but they have to be configured together, which appears not to be completely done…
                                  juantata @sdetweil
                                  The keyword, MMM-AssistantMk2 and MMM-Hotword work great. I pass the start of MM
                                  • ? Offline
                                    @juantata
                                    So, What you need is just playing video by your voice, you don’t need MMM-Youtube. Youtube playing feature is already implemented in MMM-AssistantMk2. Remove MMM-Youtube.
                                    • rafaelcotaR Offline
                                      rafaelcota @Guest
                                      @Sean Great module! Had it working on first try in a Mac with TelegramBot, I’m using the “fullscreen_below” and looks awesome.
                                      I just can’t get to play a playlist from TelegramBot, I was wondering if you could give me an example of the TelegramBot /yt or /yc parameters if this can be done.
                                      Thank you in advanced,
                                      Rafael
                                      • ? Offline
                                        A Former User @rafaelcota
                                        @rafaelcota
                                        What kind of parameter did you use? Show me your trial example.
                                        rafaelcotaR 1 Reply Last reply Reply Quote 0
                                          rafaelcota @Guest
                                          @Sean I’m typing something like this:
                                          /yt https://www.youtube.com/playlist?list=PL55713C70BA91BD6E
                                          no luck.
                                          /yt playlist playlist PL55713C70BA91BD6E
                                          no luck
                                          /yt type:playlist listType:playlis id:PL55713C70BA91BD6E
                                          no luck
                                          Thank you for your help.
                                          ? 2 Replies Last reply Reply Quote 0
                                          • ? Offline
                                            @rafaelcota
                                            Sorry, /yt doesn’t support playlist at this moment, but I’ll provide a fix soon. (in a few hours)
                                            • 2 / 4
