    MMM-YouTube
    64 Posts 15 Posters 39.2k Views 16 Watching
      juantata @juantata
      @juantata
      Wrongly asked the question
        juantata @Guest
        @Sean
        How do you make the module work?
          sdetweil @juantata
          @juantata you need some other module to send it a command (notification)
          see the doc
          https://github.com/eouia/MMM-YouTube
            juantata @sdetweil
            MMM-TelegramBot?
            If this is, I thought it was optional.
              sdetweil @juantata
              @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
              depends on what you want to do…
                juantata @sdetweil
                All I want is to say
                for example:
                “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                  juantata @sdetweil
                  If that were not possible, could you tell me, if it is not a problem, the configuration of MMM-TelegramBot?
                    sdetweil @juantata
                    @juantata said in MMM-YouTube:
                    MMM-TelegramBot
                    see the readme https://github.com/eouia/MMM-TelegramBot
                    there are three pieces to your desired result
                    something to hear ‘Ok Google’ (the hotword, as the mic is listening ALL the time, so only want it to trigger after a wakeup/hotword), just like real devices, MMM-Hotword
                    something to decode your voice and return words and maybe act, MMM-AssistantMk2 does this for google…
                    and something to play from youtube… which it looks like MMM-Youtube does…
                    I use MMM-Hotword and MMM-AssistantMk2 to answer questions and put mirror to sleep/wake up.
                    i don’t play videos or music on the mirror
                    but they have to be configured together, which appears not to be completely done…
                      juantata @sdetweil
                      The keyword, MMM-AssistantMk2 and MMM-Hotword work great. I pass the start of MM
                        A Former User @juantata
                        @juantata
                        So, What you need is just playing video by your voice, you don’t need MMM-Youtube. Youtube playing feature is already implemented in MMM-AssistantMk2. Remove MMM-Youtube.
                        • rafaelcotaR Offline
                          rafaelcota @Guest
                          @Sean Great module! Had it working on first try in a Mac with TelegramBot, I’m using the “fullscreen_below” and looks awesome.
                          I just can’t get to play a playlist from TelegramBot, I was wondering if you could give me an example of the TelegramBot /yt or /yc parameters if this can be done.
                          Thank you in advanced,
                          Rafael
                            A Former User @rafaelcota
                            @rafaelcota
                            What kind of parameter did you use? Show me your trial example.
                            rafaelcotaR 1 Reply Last reply Reply Quote 0
                              rafaelcota @Guest
                              @Sean I’m typing something like this:
                              /yt https://www.youtube.com/playlist?list=PL55713C70BA91BD6E
                              no luck.
                              /yt playlist playlist PL55713C70BA91BD6E
                              no luck
                              /yt type:playlist listType:playlis id:PL55713C70BA91BD6E
                              no luck
                              Thank you for your help.
                                @rafaelcota
                                Sorry, /yt doesn’t support playlist at this moment, but I’ll provide a fix soon. (in a few hours)
                                  @rafaelcota
                                  updated. try again after update.
                                  you can play playlist like this; /yl PL55713C70BA91BD6E
                                    rafaelcota @Guest
                                    @Sean Thank you very much
                                      rafaelcota @Guest
                                      Hi @Sean,
                                      I did the git pull and then try it, but I can’t seem to make it do anything, even the /yt commands that already were working.
                                      All I can see is this message in the console:
                                      [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number
                                      And nothing happens in the mirror screen, not with /yt or /yl. If I do a /yc getVolume it gives me the right number, so I get the module is loaded.
                                      My config is:
                                      disabled: false,
                                      module: “MMM-YouTube”,
                                      position: “fullscreen_below”,
                                      verbose:true,
                                      Any ideas where I should look?
                                      Thanks in advanced
                                        @rafaelcota
                                        Well, with my test, there is no problem to execute at all.
                                        If you see [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number, your telegram messages are received properly.
                                        Check if you have a front-end error. (With npm start dev or Ctrl+i)
                                        Or you can check by removing all other modules from config except MMM-YouTube and MMM-TelegramBot.
                                          rafaelcota @Guest
                                          @Sean Thank you again,
                                          Just as data, could be useful or not, I can play just some videos; with only TelegramBot and MMM-YouTube modules loaded or with all I got, it doesn’t matter:
                                          PLAY OK
                                          /yt https://youtu.be/5KJiO8W9iyg
                                          DOESN’T PLAY (the mirror does nothing at all)
                                          /yt https://youtu.be/y83x7MgzWOA
                                          /yl PLDIoUOhQQPlXr63I_vwF9GD8sAKh77dWU
                                            @rafaelcota said in MMM-YouTube:
                                            Hmmm. with my test, it works well.
                                            With verbose:true option, in dev-console you can see what’s going on. Try and tell me what’s significantly suspicious?
                                            • 2 / 4
