    MMM-YouTube
    64 Posts 15 Posters 41.5k Views 16 Watching
    • rafaelcotaR
      rafaelcota @Guest
      @Sean Great module! Had it working on first try in a Mac with TelegramBot, I’m using the “fullscreen_below” and looks awesome.
      I just can’t get to play a playlist from TelegramBot, I was wondering if you could give me an example of the TelegramBot /yt or /yc parameters if this can be done.
      Thank you in advanced,
      Rafael
      ? 1 Reply Last reply
        A Former User @rafaelcota
        @rafaelcota
        What kind of parameter did you use? Show me your trial example.
        rafaelcotaR 1 Reply Last reply
        • rafaelcotaR
          rafaelcota @Guest
          @Sean I’m typing something like this:
          /yt https://www.youtube.com/playlist?list=PL55713C70BA91BD6E
          no luck.
          /yt playlist playlist PL55713C70BA91BD6E
          no luck
          /yt type:playlist listType:playlis id:PL55713C70BA91BD6E
          no luck
          Thank you for your help.
          ? 2 Replies Last reply
            @rafaelcota
            Sorry, /yt doesn’t support playlist at this moment, but I’ll provide a fix soon. (in a few hours)
              @rafaelcota
              updated. try again after update.
              you can play playlist like this; /yl PL55713C70BA91BD6E
              • rafaelcotaR
                rafaelcota @Guest
                @Sean Thank you very much
                • rafaelcotaR
                  rafaelcota @Guest
                  Hi @Sean,
                  I did the git pull and then try it, but I can’t seem to make it do anything, even the /yt commands that already were working.
                  All I can see is this message in the console:
                  [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number
                  And nothing happens in the mirror screen, not with /yt or /yl. If I do a /yc getVolume it gives me the right number, so I get the module is loaded.
                  My config is:
                  disabled: false,
                  module: “MMM-YouTube”,
                  position: “fullscreen_below”,
                  verbose:true,
                  Any ideas where I should look?
                  Thanks in advanced
                    @rafaelcota
                    Well, with my test, there is no problem to execute at all.
                    If you see [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number, your telegram messages are received properly.
                    Check if you have a front-end error. (With npm start dev or Ctrl+i)
                    Or you can check by removing all other modules from config except MMM-YouTube and MMM-TelegramBot.
                    • rafaelcotaR
                      rafaelcota @Guest
                      @Sean Thank you again,
                      Just as data, could be useful or not, I can play just some videos; with only TelegramBot and MMM-YouTube modules loaded or with all I got, it doesn’t matter:
                      PLAY OK
                      /yt https://youtu.be/5KJiO8W9iyg
                      DOESN’T PLAY (the mirror does nothing at all)
                      /yt https://youtu.be/y83x7MgzWOA
                      /yl PLDIoUOhQQPlXr63I_vwF9GD8sAKh77dWU
                        @rafaelcota said in MMM-YouTube:
                        Hmmm. with my test, it works well.
                        With verbose:true option, in dev-console you can see what’s going on. Try and tell me what’s significantly suspicious?
                        • rafaelcotaR
                          rafaelcota @Guest
                          @Sean The messages are now clear, “Not allowed By Owner”
                          I guess there’s nothing I can do but finding videos that are allowed to be played outside YouTube.
                          Thank’s again
                            mosheva
                            I’m wondering if it possible to run the module but to not display the video?
                            I would like to have just the audio.
                            Thanks.
                              A Former User @mosheva
                              @mosheva
                              Hmmmm… difficult question. Maybe with CSS, it could be but I haven’t tested.
                              M 1 Reply Last reply
                                mosheva @Guest
                                @Sean @Sean Thanks, is there a way to make the youtube screen 1px by 1px? :)
                                the smaller option in the code is “small”…
                                • I
                                  iwaldrum
                                  Love the module. Is it possible to add a feature to allow you to change the video being streamed after a certain amount of time? I’d like to cycle through multiple live video camera streams.
                                  • E
                                    Egnos
                                    Hi @Sean ,
                                    I installed your module and thank you for your effort.
                                    I did not understand how do I send YouTube videos to the MM …
                                    Could you explain to me?
                                    Many thanks.
                                      A Former User @Egnos
                                      @Egnos
                                      You can use a few methods; via TelegramBot commands, notifications from other modules.
                                      Which usecase are you considering?
                                      • E
                                        Egnos
                                        Thanks @Sean
                                        Unfortunately I thought there was the possibility of sending youtube videos via smartphone using “RaspiCast” or something similar…
                                        Could you recommend some module?
                                          @Egnos
                                          MMM-TelegramBot. You can send like this on telegram;
                                          /yt https://www.youtube.com/watch?v=dAB3gziF9R4
                                          Or you can use MMM-Remote-Control or other HTTP Request Receiver modules (e.g: MMM-NotificationTrigger),
                                          But additional typing is somewhat annoying.
                                          • E
                                            Egnos
                                            @Sean said in MMM-YouTube:
                                            MMM-Remote-Control
                                            Thanks for your advises, but I chose to use RaspiCast directly to share the videos (when the video ends the MM returns…).
                                            Do you know how to mute the sound of the MM (not the Raspberry …)?
                                            • 3 / 4
