    MMM-YouTube
    64 Posts 15 Posters 38.2k Views 16 Watching
      [[global:former-user]] @rafaelcota
      @rafaelcota
      Well, with my test, there is no problem to execute at all.
      If you see [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number, your telegram messages are received properly.
      Check if you have a front-end error. (With npm start dev or Ctrl+i)
      Or you can check by removing all other modules from config except MMM-YouTube and MMM-TelegramBot.
      rafaelcotaR 1 Reply Last reply Reply Quote 0
      • rafaelcotaR Offline
        rafaelcota @Guest
        @Sean Thank you again,
        Just as data, could be useful or not, I can play just some videos; with only TelegramBot and MMM-YouTube modules loaded or with all I got, it doesn’t matter:
        PLAY OK
        /yt https://youtu.be/5KJiO8W9iyg
        DOESN’T PLAY (the mirror does nothing at all)
        /yt https://youtu.be/y83x7MgzWOA
        /yl PLDIoUOhQQPlXr63I_vwF9GD8sAKh77dWU
          @rafaelcota said in MMM-YouTube:
          Hmmm. with my test, it works well.
          With verbose:true option, in dev-console you can see what’s going on. Try and tell me what’s significantly suspicious?
            rafaelcota @Guest
            @Sean The messages are now clear, “Not allowed By Owner”
            I guess there’s nothing I can do but finding videos that are allowed to be played outside YouTube.
            Thank’s again
              mosheva
              I’m wondering if it possible to run the module but to not display the video?
              I would like to have just the audio.
              Thanks.
                [[global:former-user]] @mosheva
                @mosheva
                Hmmmm… difficult question. Maybe with CSS, it could be but I haven’t tested.
                  mosheva @Guest
                  @Sean @Sean Thanks, is there a way to make the youtube screen 1px by 1px? :)
                  the smaller option in the code is “small”…
                  • I Offline
                    iwaldrum
                    Love the module. Is it possible to add a feature to allow you to change the video being streamed after a certain amount of time? I’d like to cycle through multiple live video camera streams.
                    • E Offline
                      Egnos
                      Hi @Sean ,
                      I installed your module and thank you for your effort.
                      I did not understand how do I send YouTube videos to the MM …
                      Could you explain to me?
                      Many thanks.
                        [[global:former-user]] @Egnos
                        @Egnos
                        You can use a few methods; via TelegramBot commands, notifications from other modules.
                        Which usecase are you considering?
                        • E Offline
                          Egnos
                          Thanks @Sean
                          Unfortunately I thought there was the possibility of sending youtube videos via smartphone using “RaspiCast” or something similar…
                          Could you recommend some module?
                            @Egnos
                            MMM-TelegramBot. You can send like this on telegram;
                            /yt https://www.youtube.com/watch?v=dAB3gziF9R4
                            Or you can use MMM-Remote-Control or other HTTP Request Receiver modules (e.g: MMM-NotificationTrigger),
                            But additional typing is somewhat annoying.
                            • E Offline
                              Egnos
                              @Sean said in MMM-YouTube:
                              MMM-Remote-Control
                              Thanks for your advises, but I chose to use RaspiCast directly to share the videos (when the video ends the MM returns…).
                              Do you know how to mute the sound of the MM (not the Raspberry …)?
                                [[global:former-user]] @iwaldrum
                                @iwaldrum
                                Well, ideally possible. But I think you’d better make playlist to play several video sequentially.
                                • I Offline
                                  iwaldrum @Guest
                                  @Sean Thanks Sean. Is there a way to limit the amount of time for each video in the playlist? Only play for 30 seconds, then switch to the next video in the playlist?
                                    @iwaldrum
                                    Maybe possible. As far as I know, There are several scheduling modules. Or you can use cron. Emit notification per 30 seconds.
                                    But, If I were you, I would just make a summary video clip with 30 seconds of each videos. :D
                                      ArthurOff
                                      Hi! How do I get rid of black borders around the video, i.e. stretch/fill/crop the video?
                                      • bugsounetB Offline
                                        bugsounet Banned
                                        @csoogos : and yes … it’s dead and this module is not maintened ;)
                                        Actually, just only one module with youtube feature works ;)
                                        S 1 Reply Last reply Reply Quote -1
                                          Shinigami @bugsounet
                                          @bugsounet Good morning and happy Sunday. I would like to ask you which youtube module works?
                                          • H Offline
                                            hogedir
                                            Same question : I want to use youtube (via iframe or not), how can it be possible with the actual version of Magic mirror ? please ! thanks
                                            • 3 / 4
