    MMM-YouTube
    64 Posts 15 Posters 37.0k Views 16 Watching
      A Former User @mosheva
      @mosheva
      Hmmmm… difficult question. Maybe with CSS, it could be but I haven’t tested.
        mosheva @Guest
        @Sean @Sean Thanks, is there a way to make the youtube screen 1px by 1px? :)
        the smaller option in the code is “small”…
        • I Offline
          iwaldrum
          Love the module. Is it possible to add a feature to allow you to change the video being streamed after a certain amount of time? I’d like to cycle through multiple live video camera streams.
          • E Offline
            Egnos
            Hi @Sean ,
            I installed your module and thank you for your effort.
            I did not understand how do I send YouTube videos to the MM …
            Could you explain to me?
            Many thanks.
              A Former User @Egnos
              @Egnos
              You can use a few methods; via TelegramBot commands, notifications from other modules.
              Which usecase are you considering?
              • E Offline
                Egnos
                Thanks @Sean
                Unfortunately I thought there was the possibility of sending youtube videos via smartphone using “RaspiCast” or something similar…
                Could you recommend some module?
                  @Egnos
                  MMM-TelegramBot. You can send like this on telegram;
                  /yt https://www.youtube.com/watch?v=dAB3gziF9R4
                  Or you can use MMM-Remote-Control or other HTTP Request Receiver modules (e.g: MMM-NotificationTrigger),
                  But additional typing is somewhat annoying.
                  • E Offline
                    Egnos
                    @Sean said in MMM-YouTube:
                    MMM-Remote-Control
                    Thanks for your advises, but I chose to use RaspiCast directly to share the videos (when the video ends the MM returns…).
                    Do you know how to mute the sound of the MM (not the Raspberry …)?
                      A Former User @iwaldrum
                      @iwaldrum
                      Well, ideally possible. But I think you’d better make playlist to play several video sequentially.
                      • I Offline
                        iwaldrum @Guest
                        @Sean Thanks Sean. Is there a way to limit the amount of time for each video in the playlist? Only play for 30 seconds, then switch to the next video in the playlist?
                          @iwaldrum
                          Maybe possible. As far as I know, There are several scheduling modules. Or you can use cron. Emit notification per 30 seconds.
                          But, If I were you, I would just make a summary video clip with 30 seconds of each videos. :D
                            ArthurOff
                            Hi! How do I get rid of black borders around the video, i.e. stretch/fill/crop the video?
                            • bugsounetB Offline
                              bugsounet Banned
                              @csoogos : and yes … it’s dead and this module is not maintened ;)
                              Actually, just only one module with youtube feature works ;)
                              S 1 Reply Last reply Reply Quote -1
                                Shinigami @bugsounet
                                @bugsounet Good morning and happy Sunday. I would like to ask you which youtube module works?
                                • H Offline
                                  hogedir
                                  Same question : I want to use youtube (via iframe or not), how can it be possible with the actual version of Magic mirror ? please ! thanks
                                    MMRIZE @hogedir
                                    @hogedir @Shinigami
                                    I didn’t test all the feature, but still working as expected in MM 2.26.
                                    Tested config is here;
                                    	module: "MMM-YouTube",
                                    		defaultQuality: "default",
                                    		width: "400px",
                                    		height: "300px",
                                    		onStartPlay: {
                                    			type: "id",
                                    			shuffle: true,
                                    			loop: false,
                                    			autoplay: true,
                                    • 3 / 4
