    MMM-YouTube
    64 Posts 15 Posters 41.0k Views 16 Watching
      juantata @Guest
      @Sean An update is available for the MM-Youtube module.
      Your current installation is 1 commint changes behind the master branch.
        juantata @Guest
          A Former User @juantata
          @juantata Go to MMM-YouTube directory then do the command git pull, but the update was not so important so you can ignore it.
            juantata @Guest
            @Sean Hi. I’m sorry to give you the can so much.
            To call the youtube module I say:
            Ok google + singer’s name + song title, and the result is this
            The result is the same with any video I request.
            S ? 2 Replies Last reply Reply Quote 0
              sdetweil @juantata
              @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
              edit ~/MagicMirror/js/electron.js
              make sure the line below is present
              // Keep a global reference of the window object, if you don't, the window will
              // be closed automatically when the JavaScript object is garbage collected.
              let mainWindow;
              function createWindow() {
              	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
              if not, add it then stop and restart MagicMirror
                juantata @sdetweil
                the video finds him
                The electron.js file
                  sdetweil @juantata
                  @juantata great info… but then not the problem…
                    @juantata said in MMM-YouTube:
                    I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
                    J 3 Replies Last reply Reply Quote 0
                      juantata @Guest
                        juantata @Guest
                        @Sean
                        How do you use the module?
                          juantata @juantata
                          @juantata
                          Wrongly asked the question
                            juantata @Guest
                            @Sean
                            How do you make the module work?
                              sdetweil @juantata
                              @juantata you need some other module to send it a command (notification)
                              see the doc
                              https://github.com/eouia/MMM-YouTube
                                juantata @sdetweil
                                MMM-TelegramBot?
                                If this is, I thought it was optional.
                                  sdetweil @juantata
                                  @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
                                  depends on what you want to do…
                                    juantata @sdetweil
                                    All I want is to say
                                    for example:
                                    “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                                      juantata @sdetweil
                                      If that were not possible, could you tell me, if it is not a problem, the configuration of MMM-TelegramBot?
                                        sdetweil @juantata
                                        MMM-TelegramBot
                                        see the readme https://github.com/eouia/MMM-TelegramBot
                                        there are three pieces to your desired result
                                        something to hear ‘Ok Google’ (the hotword, as the mic is listening ALL the time, so only want it to trigger after a wakeup/hotword), just like real devices, MMM-Hotword
                                        something to decode your voice and return words and maybe act, MMM-AssistantMk2 does this for google…
                                        and something to play from youtube… which it looks like MMM-Youtube does…
                                        I use MMM-Hotword and MMM-AssistantMk2 to answer questions and put mirror to sleep/wake up.
                                        i don’t play videos or music on the mirror
                                        but they have to be configured together, which appears not to be completely done…
                                          juantata @sdetweil
                                          The keyword, MMM-AssistantMk2 and MMM-Hotword work great. I pass the start of MM
                                            @juantata
                                            So, What you need is just playing video by your voice, you don’t need MMM-Youtube. Youtube playing feature is already implemented in MMM-AssistantMk2. Remove MMM-Youtube.
                                            • 2 / 4
