    MMM-YouTube
    64 Posts 15 Posters 41.5k Views 16 Watching
      juantata @Guest
      @Sean Hi. I’m sorry to give you the can so much.
      To call the youtube module I say:
      Ok google + singer’s name + song title, and the result is this
      The result is the same with any video I request.
      S ? 2 Replies Last reply
        sdetweil @juantata
        @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
        edit ~/MagicMirror/js/electron.js
        make sure the line below is present
        // Keep a global reference of the window object, if you don't, the window will
        // be closed automatically when the JavaScript object is garbage collected.
        let mainWindow;
        function createWindow() {
        	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
        if not, add it then stop and restart MagicMirror
        J 1 Reply Last reply
          juantata @sdetweil
          the video finds him
          The electron.js file
            sdetweil @juantata
            @juantata great info… but then not the problem…
              A Former User @juantata
              @juantata said in MMM-YouTube:
              I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
              J 3 Replies Last reply
                juantata @Guest
                  juantata @Guest
                  @Sean
                  How do you use the module?
                    juantata @juantata
                    @juantata
                    Wrongly asked the question
                      juantata @Guest
                      @Sean
                      How do you make the module work?
                        sdetweil @juantata
                        @juantata you need some other module to send it a command (notification)
                        see the doc
                        https://github.com/eouia/MMM-YouTube
                          juantata @sdetweil
                          MMM-TelegramBot?
                          If this is, I thought it was optional.
                            sdetweil @juantata
                            @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
                            depends on what you want to do…
                            J 2 Replies Last reply
                              juantata @sdetweil
                              All I want is to say
                              for example:
                              “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                                juantata @sdetweil
                                If that were not possible, could you tell me, if it is not a problem, the configuration of MMM-TelegramBot?
                                  sdetweil @juantata
                                  MMM-TelegramBot
                                  see the readme https://github.com/eouia/MMM-TelegramBot
                                  there are three pieces to your desired result
                                  something to hear ‘Ok Google’ (the hotword, as the mic is listening ALL the time, so only want it to trigger after a wakeup/hotword), just like real devices, MMM-Hotword
                                  something to decode your voice and return words and maybe act, MMM-AssistantMk2 does this for google…
                                  and something to play from youtube… which it looks like MMM-Youtube does…
                                  I use MMM-Hotword and MMM-AssistantMk2 to answer questions and put mirror to sleep/wake up.
                                  i don’t play videos or music on the mirror
                                  but they have to be configured together, which appears not to be completely done…
                                    juantata @sdetweil
                                    The keyword, MMM-AssistantMk2 and MMM-Hotword work great. I pass the start of MM
                                    ? 1 Reply Last reply
                                      @juantata
                                      So, What you need is just playing video by your voice, you don’t need MMM-Youtube. Youtube playing feature is already implemented in MMM-AssistantMk2. Remove MMM-Youtube.
                                      • rafaelcotaR
                                        rafaelcota @Guest
                                        @Sean Great module! Had it working on first try in a Mac with TelegramBot, I’m using the “fullscreen_below” and looks awesome.
                                        I just can’t get to play a playlist from TelegramBot, I was wondering if you could give me an example of the TelegramBot /yt or /yc parameters if this can be done.
                                        Thank you in advanced,
                                        Rafael
                                          A Former User @rafaelcota
                                          @rafaelcota
                                          What kind of parameter did you use? Show me your trial example.
                                          rafaelcotaR 1 Reply Last reply
                                          • rafaelcotaR
                                            rafaelcota @Guest
                                            @Sean I’m typing something like this:
                                            /yt https://www.youtube.com/playlist?list=PL55713C70BA91BD6E
                                            no luck.
                                            /yt playlist playlist PL55713C70BA91BD6E
                                            no luck
                                            /yt type:playlist listType:playlis id:PL55713C70BA91BD6E
                                            no luck
                                            Thank you for your help.
                                            • 2 / 4
