    MMM-YouTube
    64 Posts 15 Posters 32.0k Views 16 Watching
      sdetweil @juantata
      @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
      edit ~/MagicMirror/js/electron.js
      make sure the line below is present
      // Keep a global reference of the window object, if you don't, the window will
      // be closed automatically when the JavaScript object is garbage collected.
      let mainWindow;
      function createWindow() {
      	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
      if not, add it then stop and restart MagicMirror
        juantata @sdetweil
        the video finds him
        The electron.js file
          sdetweil @juantata
          @juantata great info… but then not the problem…
            A Former User @juantata
            @juantata said in MMM-YouTube:
            To call the youtube module I say:
            Ok google + singer’s name + song title, and the result is this
            I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
            J 3 Replies Last reply Reply Quote 0
              juantata @Guest
                juantata @Guest
                @Sean
                How do you use the module?
                  juantata @juantata
                  @juantata
                  Wrongly asked the question
                    juantata @Guest
                    @Sean
                    How do you make the module work?
                      sdetweil @juantata
                      @juantata you need some other module to send it a command (notification)
                      see the doc
                      https://github.com/eouia/MMM-YouTube
                        juantata @sdetweil
                        MMM-TelegramBot?
                        If this is, I thought it was optional.
                        • 3 / 7
