    MMM-YouTube
    64 Posts 15 Posters 38.2k Views 16 Watching
      juantata @Guest
      @Sean
      How do you use the module?
        juantata @juantata
        @juantata
        Wrongly asked the question
          juantata @Guest
          @Sean
          How do you make the module work?
            sdetweil @juantata
            @juantata you need some other module to send it a command (notification)
            see the doc
            https://github.com/eouia/MMM-YouTube
              juantata @sdetweil
              MMM-TelegramBot?
              If this is, I thought it was optional.
                sdetweil @juantata
                @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
                depends on what you want to do…
                  juantata @sdetweil
                  All I want is to say
                  for example:
                  “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                    juantata @sdetweil
                    If that were not possible, could you tell me, if it is not a problem, the configuration of MMM-TelegramBot?
                      sdetweil @juantata
                      @juantata said in MMM-YouTube:
                      MMM-TelegramBot
                      see the readme https://github.com/eouia/MMM-TelegramBot
                      there are three pieces to your desired result
                      something to hear ‘Ok Google’ (the hotword, as the mic is listening ALL the time, so only want it to trigger after a wakeup/hotword), just like real devices, MMM-Hotword
                      something to decode your voice and return words and maybe act, MMM-AssistantMk2 does this for google…
                      and something to play from youtube… which it looks like MMM-Youtube does…
                      I use MMM-Hotword and MMM-AssistantMk2 to answer questions and put mirror to sleep/wake up.
                      i don’t play videos or music on the mirror
                      but they have to be configured together, which appears not to be completely done…
                        juantata @sdetweil
                        The keyword, MMM-AssistantMk2 and MMM-Hotword work great. I pass the start of MM
                          [[global:former-user]] @juantata
                          @juantata
                          So, What you need is just playing video by your voice, you don’t need MMM-Youtube. Youtube playing feature is already implemented in MMM-AssistantMk2. Remove MMM-Youtube.
                          • rafaelcotaR Offline
                            rafaelcota @Guest
                            @Sean Great module! Had it working on first try in a Mac with TelegramBot, I’m using the “fullscreen_below” and looks awesome.
                            I just can’t get to play a playlist from TelegramBot, I was wondering if you could give me an example of the TelegramBot /yt or /yc parameters if this can be done.
                            Thank you in advanced,
                            Rafael
                              [[global:former-user]] @rafaelcota
                              @rafaelcota
                              What kind of parameter did you use? Show me your trial example.
                              rafaelcotaR 1 Reply Last reply Reply Quote 0
                                rafaelcota @Guest
                                @Sean I’m typing something like this:
                                /yt https://www.youtube.com/playlist?list=PL55713C70BA91BD6E
                                no luck.
                                /yt playlist playlist PL55713C70BA91BD6E
                                no luck
                                /yt type:playlist listType:playlis id:PL55713C70BA91BD6E
                                no luck
                                Thank you for your help.
                                  @rafaelcota
                                  Sorry, /yt doesn’t support playlist at this moment, but I’ll provide a fix soon. (in a few hours)
                                    @rafaelcota
                                    updated. try again after update.
                                    you can play playlist like this; /yl PL55713C70BA91BD6E
                                      rafaelcota @Guest
                                      @Sean Thank you very much
                                        rafaelcota @Guest
                                        Hi @Sean,
                                        I did the git pull and then try it, but I can’t seem to make it do anything, even the /yt commands that already were working.
                                        All I can see is this message in the console:
                                        [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number
                                        And nothing happens in the mirror screen, not with /yt or /yl. If I do a /yc getVolume it gives me the right number, so I get the module is loaded.
                                        My config is:
                                        disabled: false,
                                        module: “MMM-YouTube”,
                                        position: “fullscreen_below”,
                                        verbose:true,
                                        Any ideas where I should look?
                                        Thanks in advanced
                                          @rafaelcota
                                          Well, with my test, there is no problem to execute at all.
                                          If you see [TELBOT] [2019-11-04 12:26:04]Message is cominf from CHAT: Number, your telegram messages are received properly.
                                          Check if you have a front-end error. (With npm start dev or Ctrl+i)
                                          Or you can check by removing all other modules from config except MMM-YouTube and MMM-TelegramBot.
                                            rafaelcota @Guest
                                            @Sean Thank you again,
                                            Just as data, could be useful or not, I can play just some videos; with only TelegramBot and MMM-YouTube modules loaded or with all I got, it doesn’t matter:
                                            PLAY OK
                                            /yt https://youtu.be/5KJiO8W9iyg
                                            DOESN’T PLAY (the mirror does nothing at all)
                                            /yt https://youtu.be/y83x7MgzWOA
                                            /yl PLDIoUOhQQPlXr63I_vwF9GD8sAKh77dWU
                                            • 2 / 4
