    MMM-YouTube
    64 Posts 15 Posters 38.2k Views 16 Watching
      juantata @sdetweil
      Hi. I don’t know where it could be wrong. I have copied it the same.
        [[global:former-user]] @juantata
        @juantata
        I don’t know Spanish at all, Anyway “El video no esta disvonible” looks like “The video is not available”
        The reason would be various.
        • The clip is removed (sometimes it is searchable but not playable)
        • The clip is not allowed to be played outside of YouTube websites by it’s right owner. (I don’t know why owners restrict their clip, but some did)
        Anyway, that is not the issue of module itself.
          juantata @Guest
          @Sean Hi. It asks me to update. How is it done?
            @juantata ???
              juantata @Guest
              @Sean An update is available for the MM-Youtube module.
              Your current installation is 1 commint changes behind the master branch.
                juantata @Guest
                  @juantata Go to MMM-YouTube directory then do the command git pull, but the update was not so important so you can ignore it.
                    juantata @Guest
                    @Sean Hi. I’m sorry to give you the can so much.
                    To call the youtube module I say:
                    Ok google + singer’s name + song title, and the result is this
                    The result is the same with any video I request.
                    S ? 2 Replies Last reply Reply Quote 0
                      sdetweil @juantata
                      @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
                      edit ~/MagicMirror/js/electron.js
                      make sure the line below is present
                      // Keep a global reference of the window object, if you don't, the window will
                      // be closed automatically when the JavaScript object is garbage collected.
                      let mainWindow;
                      function createWindow() {
                      	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
                      if not, add it then stop and restart MagicMirror
                        juantata @sdetweil
                        the video finds him
                        The electron.js file
                          sdetweil @juantata
                          @juantata great info… but then not the problem…
                            @juantata said in MMM-YouTube:
                            I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
                            J 3 Replies Last reply Reply Quote 0
                              juantata @Guest
                                juantata @Guest
                                @Sean
                                How do you use the module?
                                  juantata @juantata
                                  @juantata
                                  Wrongly asked the question
                                    juantata @Guest
                                    @Sean
                                    How do you make the module work?
                                      sdetweil @juantata
                                      @juantata you need some other module to send it a command (notification)
                                      see the doc
                                      https://github.com/eouia/MMM-YouTube
                                        juantata @sdetweil
                                        MMM-TelegramBot?
                                        If this is, I thought it was optional.
                                          sdetweil @juantata
                                          @juantata there are all kinds of modules that do all kinds of things… see movement, send a notification, see a swipe of a hand, send a notification, hear words, see button press, act on a phrase…
                                          depends on what you want to do…
                                            juantata @sdetweil
                                            All I want is to say
                                            for example:
                                            “Ok Google YouTube Charlie Puth Mother” and put the video of the singer
                                            • 2 / 4
