    MMM-YouTube
    64 Posts 15 Posters 41.5k Views 16 Watching
      A Former User @juantata
      @juantata it seems not allowed. some clips are limited by right owner not to be played out of youtube
        sdetweil @juantata
        @juantata forgot the 3 backticks before and after
        J 1 Reply Last reply
          juantata @sdetweil
          @sdetweil said in MMM-YouTube:
          backticks
          Sorry but I’m a newbie. What do you mean with the three backticks?
            sdetweil @juantata
            @juantata on the US keyboard, shifted key left of the number 1 ` (like single quote, but leaning to the left) . the non shifted symbol is tidle ~
            see https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet
            Code and Syntax Highlighting
            mumblebajM 1 Reply Last reply
            • mumblebajM
              @sdetweil I thought it was the other way around? Tilda (~) was shifted and back tick (`) non shifted? :smiling_face_with_open_mouth_smiling_eyes:
                sdetweil @mumblebaj
                @mumblebaj maybe, my keyboard has them labeled backwards
                  juantata @sdetweil
                  Hi. I don’t know where it could be wrong. I have copied it the same.
                  ? 1 Reply Last reply
                    @juantata
                    I don’t know Spanish at all, Anyway “El video no esta disvonible” looks like “The video is not available”
                    The reason would be various.
                    • The clip is removed (sometimes it is searchable but not playable)
                    • The clip is not allowed to be played outside of YouTube websites by it’s right owner. (I don’t know why owners restrict their clip, but some did)
                    Anyway, that is not the issue of module itself.
                      juantata @Guest
                      @Sean Hi. It asks me to update. How is it done?
                        @juantata ???
                        J 2 Replies Last reply
                          juantata @Guest
                          @Sean An update is available for the MM-Youtube module.
                          Your current installation is 1 commint changes behind the master branch.
                            juantata @Guest
                              @juantata Go to MMM-YouTube directory then do the command git pull, but the update was not so important so you can ignore it.
                                juantata @Guest
                                @Sean Hi. I’m sorry to give you the can so much.
                                To call the youtube module I say:
                                Ok google + singer’s name + song title, and the result is this
                                The result is the same with any video I request.
                                S ? 2 Replies Last reply
                                  sdetweil @juantata
                                  @juantata what version of MagicMirror are u running? we added a fix in 2.8 to allow autoplay
                                  edit ~/MagicMirror/js/electron.js
                                  make sure the line below is present
                                  // Keep a global reference of the window object, if you don't, the window will
                                  // be closed automatically when the JavaScript object is garbage collected.
                                  let mainWindow;
                                  function createWindow() {
                                  	app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required"); //< --- this line
                                  if not, add it then stop and restart MagicMirror
                                    juantata @sdetweil
                                    the video finds him
                                    The electron.js file
                                      sdetweil @juantata
                                      @juantata great info… but then not the problem…
                                        @juantata said in MMM-YouTube:
                                        I have a little confusion. Are you talking about MMM-AssistantMk2 or MMM-Youtube? MMM-Youtube is not activated by MMM-AssistantMk2 yet. (I will connect both on next updates, but I have not enough time to focus nowadays) So I can’t catch your point at this time.
                                        J 3 Replies Last reply
                                          juantata @Guest
                                            juantata @Guest
                                            @Sean
                                            How do you use the module?
                                            • 1 / 4
