    Newsfeed "loading..."
    9 Posts 3 Posters 3.0k Views 2 Watching
    • DocVooDooD
      DocVooDoo
      Hi Guys. I have a problem with the newsfeeds. If I set the ignoreOldItems option to true, I will no longer see any feeds. It is only Loading. I have already tried a reboot, in vain.
      Who can help me here? If I set the option to “false” the feeds are displayed directly to me.
      If I start with “server only” I get no error messages in this regard …
      https://pastebin.com/THDrSAVh <-- The Config from Newsfeed
        sdetweil @DocVooDoo
        @DocVooDoo open the developers window, ctrl-shift-i, and select the console tab, then scroll up to see if there are any errors… usually red text…
        let us know
        DocVooDooD 1 Reply Last reply
        • DocVooDooD
          DocVooDoo @sdetweil
          @sdetweil Hi and thanks for the quick reply.
          Only one error …: Google Maps JavaScript API error: ApiNotActivatedMapError
          That’s from the module MMM-Fuel. I will remove the same.
            sdetweil @DocVooDoo
            @DocVooDoo ok, i changed mine to add that parm, and don’t see any different behavior… still get feed items displayed.
            • DocVooDooD
              DocVooDoo @sdetweil
              @sdetweil Is there a cache or something? Something cached? That’s really only if I activate this option …
                sdetweil @DocVooDoo
                @DocVooDoo no… no cache
                • brobergB
                  broberg Project Sponsor
                  What is the limit for old headlines and does your newsfeed have actual current headlines? (i.e are there headlines newer than the set time limit)
                  • brobergB
                    Lookin at your config you have set that it should ignore headlines that are older than what, 4.5 minutes?
                    Change the ignoreOlderThan: to at least the default 1 day which is 86400000
                    Reply Quote 1
                    • DocVooDooD
                      DocVooDoo @broberg
                      @broberg Oh, I have given seconds instead of milliseconds. Thank you for the hint !! now it works.
