Navigation
    • Search
    End MM from Terminal
    Troubleshooting
    • J
      Jeff last edited by
      if I start MM from my computer via ssh terminal, how can I finish the prozess?
      In the terminal its’s just the runnnig prozess…
      • lolobyte
        lolobyte last edited by
        Controlling you MagicMirror via PM2
        Restarting your MagicMirror
        pm2 restart mm
        Stopping your MagicMirror
        pm2 stop mm
        Show the MagicMirror logs
        pm2 logs mm
        Show the MagicMirror process information
        pm2 show mm
        https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
        • J
          Jeff last edited by Jeff
          I think that doesn’t work correctly…
          Or I made a mistake
          Bild Text
          lolobyte 1 Reply Last reply Reply Quote 0
          • broberg
            broberg Project Sponsor last edited by
            I’m just guessing, since I know nothing.
            Don’t you have to start it with pm2 to close it with pm2?
            Ie use pm2 start instead of npm start
            • D
              dbahn25 last edited by
              You have to use the pm2 service manager to be able to stop MM with pm2 stop mm
              if you just use npm start, you need to press CTRL+C to stop it.
              CTRL+C stops any running process in the terminal you are currently in (so e.g. apt-get upgrade could be stopped with it)
              • lolobyte
                lolobyte @Jeff last edited by
                @Jeff
                like u start the npm use CTRL+c or CTRL+X like dbahn25 mentioned.
                • J
                  Jeff last edited by
                  okay thanks 🙂
