    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 12.7k Views 3 Watching
      JonoGee @sdetweil
      @sdetweil I get this error message…
      pi@raspberrypi:~/MagicMirror $ sudo apt-get install libatlas-base-dev libatlas3gf-base
      Reading package lists... 0%
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      E: Unable to locate package libatlas3gf-base
        sdetweil @JonoGee
        @JonoGee have u tried starting MM now?
          JonoGee @sdetweil
          @sdetweil Just. Still crashing with the same error message
          J S 2 Replies Last reply Reply Quote 0
            JonoGee @JonoGee
            @JonoGee There is discussion about this here…
            https://github.com/Kitt-AI/snowboy/issues/126
            But i don’t understand what commands I need to run. It doesn’t read very clear to my only being an absolute amateur and all. Does it make sense to you?
              sdetweil @JonoGee
              @JonoGee is this a pi zero?
              didn’t install libatlas-base-dev.
              may have to install openblas
              I had to on my odroid
                JonoGee @sdetweil
                @sdetweil No. its a Pi3 B+
                How do i install openblas then?
                  sdetweil @JonoGee
                  @JonoGee Google search. What is r u running raspian, ubuntu?
                    JonoGee @sdetweil
                    @sdetweil Hi good morning. I am running Raspian.
                      JonoGee @JonoGee
                      @JonoGee
                      Error message I am getting now in console is as so…
                      MMM-GoogleTasks received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                      module.js:154 MMM-WatchDog received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                      module.js:154 MMM-Cursor received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                      null:1 GET http://0.0.0.0:8080/modules/MMM-Hotword/null 404 (Not Found)
                      module.js:154 MMM-Tools received a module notification: CALENDAR_EVENTS from sender: calendar
                      module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
                      I have managed to get AssistantMk2 talking to me now in mirror but Hotword/Mic is still not functioning
                        sdetweil @JonoGee
                        @JonoGee hm… used to be that you needed MMM-Hotword to hear the Alexa or OK Google (or whatever special ‘Hot’ word), that signaled MMM_AssistantMk2 to listen for search words or commands…
                        each used the mic separately, Hotword first, then Assistant.
                        I know Sean has released new versions, which I haven’t tested yet
                        • 3 / 3
