    MMM-AssistantMk2 / MMM-Hotword Issue
    28 Posts 3 Posters 15.0k Views 3 Watching
    • J
      JonoGee
      I wonder if there is someone who can help me with this issue. I have been working with eouia to trying and get these modules working together. Unfortunately without any success. I am led to believe that the Snowboy module is not compatible with my system. The Mirror opens and then crashes immediately with the following error messages…
      [HOTWORD] Detector starts listening.
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node: undefined symbol: cblas_sdot
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-06-26T15_09_51_093Z-debug.log
      I really hope someone can help me with this.
      Regards
      Jonathan
        sdetweil
        @JonoGee said in MMM-AssistantMk2 / MMM-Hotword Issue:
        cblas_
        u are missing the cblas library
        google search ‘cblas install’
        J 1 Reply Last reply
        • J
          JonoGee @sdetweil
          @sdetweil Is it the LAPACK I need to install then?
            sdetweil @JonoGee
            @JonoGee I don’t know… looking at the snowboy error itself and issues reported
            https://github.com/Kitt-AI/snowboy/issues/54
            the suggested fix is
            sudo apt-get install libatlas-base-dev libatlas3gf-base
            • J
              JonoGee @sdetweil
              @sdetweil I get this error message…
              pi@raspberrypi:~/MagicMirror $ sudo apt-get install libatlas-base-dev libatlas3gf-base
              Reading package lists... 0%
              Reading package lists... Done
              Building dependency tree
              Reading state information... Done
              E: Unable to locate package libatlas3gf-base
                sdetweil @JonoGee
                @JonoGee have u tried starting MM now?
                • J
                  JonoGee @sdetweil
                  @sdetweil Just. Still crashing with the same error message
                  J S 2 Replies Last reply
                  • J
                    JonoGee @JonoGee
                    @JonoGee There is discussion about this here…
                    https://github.com/Kitt-AI/snowboy/issues/126
                    But i don’t understand what commands I need to run. It doesn’t read very clear to my only being an absolute amateur and all. Does it make sense to you?
                      sdetweil @JonoGee
                      @JonoGee is this a pi zero?
                      didn’t install libatlas-base-dev.
                      may have to install openblas
                      I had to on my odroid
                      • J
                        JonoGee @sdetweil
                        @sdetweil No. its a Pi3 B+
                        How do i install openblas then?
                          sdetweil @JonoGee
                          @JonoGee Google search. What is r u running raspian, ubuntu?
                          • J
                            JonoGee @sdetweil
                            @sdetweil Hi good morning. I am running Raspian.
                            • J
                              JonoGee @JonoGee
                              @JonoGee
                              Error message I am getting now in console is as so…
                              MMM-GoogleTasks received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              module.js:154 MMM-WatchDog received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              module.js:154 MMM-Cursor received a module notification: HOTWORD_SLEEPING from sender: MMM-Hotword
                              null:1 GET http://0.0.0.0:8080/modules/MMM-Hotword/null 404 (Not Found)
                              module.js:154 MMM-Tools received a module notification: CALENDAR_EVENTS from sender: calendar
                              module.js:154 clock received a module notification: CALENDAR_EVENTS from sender: calendar
                              I have managed to get AssistantMk2 talking to me now in mirror but Hotword/Mic is still not functioning
                                sdetweil @JonoGee
                                @JonoGee hm… used to be that you needed MMM-Hotword to hear the Alexa or OK Google (or whatever special ‘Hot’ word), that signaled MMM_AssistantMk2 to listen for search words or commands…
                                each used the mic separately, Hotword first, then Assistant.
                                I know Sean has released new versions, which I haven’t tested yet
                                • J
                                  JonoGee @sdetweil
                                  @sdetweil As far as I am aware, I have used the latest released versions of each. I guess I’ll just have to wait and see if someone updates it or fixes problem or something. Thanks anyway for your time and help. I have made a bit of progress though. It just seems to be Snowboy now.
                                  • B
                                    BJ Duncan
                                    Have you test your microphone to see if it working in general?
                                    From home directory:
                                    arecord test.wav
                                    and talk for about 5 seconds into your microphone.
                                    Then cancel that by Ctrl+C
                                    Once you have cancelled the test check your directory to ensure that the ‘test.wav’ file is there:
                                    dir
                                    if your file shows up then you can test that file to ensure it recorded your voice from the microphone:
                                    aplay test.wav
                                    You should be able to hear back what you just recorded.
                                    If you can, that means it is a configuration setting that just needs to be tweaked. If not, then there is something wrong with either the microphone settings or audio settings within the pi itself.
                                    I will keep monitoring and let me know how you go.
                                    Regards,
                                    BJ Duncan
                                    • J
                                      JonoGee
                                      Just tested. Recording & playing back fine with arecord and aplay. No problems and no error messages. Thanks for taking the time for getting in touch anyway. I’d almost given up on this.
                                      • B
                                        BJ Duncan
                                        No dramas at all.
                                        Now you need to double check that you are pointing to the correct device number for your audio with the Assistant module.
                                        In a terminal at the root directory (pi@raspberrypi:~ ) Check the device list for audio input:
                                        arecord -l
                                        This should provide you a list of CAPTURE Hardware Devices. The numbers you want to write down is the Card number, and device number.
                                        As an example on my device I have it as Card: 2 Device: 0
                                        Now within the config.js of the MagicMirror ensure that the device number is the same. Here is what it looks like within my config.js:
                                        		  module: "MMM-AssistantMk2",
                                        		  position: "bottom_bar",
                                        		    record: {
                                        		      recordProgram : "arecord",
                                        		      device        : "plughw:2",
                                        		    notifications: {
                                        		      ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                        		      ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                        		  module: "MMM-Hotword",
                                        		    chimeOnFinish:null,
                                        		    mic: {
                                        		    models: [
                                        		        hotwords    : "smart_mirror",
                                        		        file        : "smart_mirror.umdl",
                                        		        sensitivity : "0.5",
                                        		    defaultCommand: {
                                        		      notificationExec: {
                                        		        notification: "ASSISTANT_ACTIVATE",
                                        		        payload: (detected, afterRecord) => {
                                        		          return {profile:"default"}
                                        		      afterRecordLimit:0,
                                        		      restart:false,
                                        Notice within both my modules because my card number is ‘2’, that the
                                        So make sure your number corresponds with your Card number.
                                        Give that a test and we will go from there.
                                        Regards,
                                        BJ Duncan
                                        • J
                                          JonoGee @BJ Duncan
                                          @BJ-Duncan said in MMM-AssistantMk2 / MMM-Hotword Issue:
                                          arecord -l
                                          I get this…
                                          pi@raspberrypi:~ $ arecord -l
                                          **** List of CAPTURE Hardware Devices ****
                                          card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-codec-0 []
                                            Subdevices: 1/1
                                            Subdevice #0: subdevice #0
                                          pi@raspberrypi:~ $
                                          • J
                                            JonoGee @JonoGee
                                            @JonoGee I recognised both devices as 0 so I changed accordingly. Now i get this error message. Mirror opens but closes immediately…
                                            [MMM-PushBulletNotifications][Info] 13:58:15.164 - PushBullet connected
                                            [HOTWORD] begins.
                                            npm ERR! file sh
                                            npm ERR!
                                            npm ERR!     /home/pi/.npm/_logs/2019-07-01T12_58_15_977Z-debug.log
