    8 Posts 7 Posters 14.7k Views 6 Watching
    • N Offline
      Nik
      Hi guys,
      just tried installing the Magic Mirror (curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash). Getting the following message; can anyone help me?
      Run apt-get install nodejs (as root) to install Node.js v6.x and npm
      Reading package lists… Done
      Building dependency tree
      Reading state information… Done
      nodejs is already the newest version.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Node.js installation Done!
      Cloning MagicMirror …
      Cloning into ‘MagicMirror’…
      remote: Counting objects: 4734, done.
      remote: Compressing objects: 100% (34/34), done.
      remote: Total 4734 (delta 15), reused 0 (delta 0), pack-reused 4698
      Receiving objects: 100% (4734/4734), 10.49 MiB | 1.62 MiB/s, done.
      Resolving deltas: 100% (2502/2502), done.
      Cloning MagicMirror Done!
      Installing dependencies …
      bash: line 109: npm: command not found
      1 Reply Last reply Reply Quote -1
      • G Offline
        gshimself
        Hi. Dod you do: Enter the repository: cd ~/MagicMirror and then Install and run the app: “npm install && npm start” ?
        • brobergB Offline
          broberg Project Sponsor
          Also, have you tried just running tha script again? I had to run it a couple of times to get it to install everything
          • N Offline
            Nik
            @gshimself -bash: npm: command not found
            @broberg Yes, will try it again now, but it didn´t work for me D:
            indigomejorI 1 Reply Last reply Reply Quote 0
            • indigomejorI Offline
              indigomejor @Nik
              @Nik Hi, I had almost same problem, I solved it by installing nodejs and electron first before MM
              used those links http://thisdavej.com/beginners-guide-to-installing-node-js-on-a-raspberry-pi/ - in 3/4 of page
              and for electron I think I used this https://github.com/electron/electron-quick-start dont remember… sorry :/
              • bheplerB Offline
                bhepler Module Developer
                Two questions: What version of the Raspberry Pi are you running and are you using the Raspian Lite version?
                  roramirez Core Contributors
                  said in Unable to install dependencies!:
                  What say the command
                  dpkg -L nodejs
                  I understand the nodejs is not necesary install manually, the script do it for you.
                  Try, uninstall the nodejs from the repository and run again the bash installer.
                  Easy module development with MagicMirror Module Template
                  • V Offline
                    Vladis466
                    Update received same error running the bash script:
                    on Raspberry pi 3.0 -B. Installed Raspbian Jesse using NOOBS.
                    Ran the script again and the response told me NodeJs was installed, “Magic mirror is already installed”
                    I believe this is more an unintended response of the actual bug. NodeJS was already installed correctly?
                    Anyway,
                    navigated into the folder MagicMirror:
                    npm start -> electron not installed fail.
                    npm install -> npm start
                    Bingo, we are running. No need to download any packages seperately.
