    MMM-Clap
    25 Posts 4 Posters 9.2k Views 2 Watching
    • ? Offline
      A Former User
      MMM-Clap
      MagicMirror controller by hand-clap or finger-snap
      screenshot
      By example, you can hide modules by finger-snapping like Thanos.
      Features
      • Count and Sequence could be detected.
      • As a result of detection, notification or shell command could be executed.
      [card:eouia/MMM-Clap]
      S 1 Reply Last reply Reply Quote 2
        bhepler Module Developer
        To implement this in proper Thanos fashion, you should hide half of the modules after a finger snap.
        Great idea. Thanks!
          smarthome @Guest
          @Sean
          I’ve just configured MMM-Clap to work with MMM Assistant MK2 OK. But can’t work with MMM-Page-Selector and other modules that needs more than one notification trigger parameter,(MMM Assistant MK2 has only one )
          this.sendNotification("PAGE_SELECT", "2");
          This is my code in MMM-Clap
          defaultCommandMode: "MODE_DEFAULT",
          				commands: {
          				  "MODE_DEFAULT": {
          					"1": {
          					  notificationExec: {
          						notification: "PAGE_SELECT",
          						payload: {profile: "1"}
          					  restart:flase,
          And still can not call CLAP_RESUME & CLAP_PAUSE in notification trigger out of these module, because of it hasn’t got this function
          Tks and waitting for you response !
          • Cr4z33C Offline
            Cr4z33
            Nice @Sean!
            This is perfect to turn on my mirror display! :smiling_face_with_open_mouth_closed_eyes:
            • ? Offline
              A Former User @smarthome
              @smarthome
              I cannot understand your intention.
              Why did you use {profile: "1"} as parameter of PAGE_SELECT?
              I think this would;
              "1": {
                notificationExec: {
                  payload: 1
              • ? Offline
                A Former User @Cr4z33
                @Cr4z33 Thanks. I think this would be better than untrustworthy Hotword
                  smarthome @Guest
                  @Sean
                  "1": {
                    notificationExec: {
                      payload: 1
                  It’s worked to send from MMM-Clap to MMM-Page-Selector
                  But still can not call CLAP_RESUME & CLAP_PAUSE in notification trigger out of these modules, because of it hasn’t got this function
                  • Cr4z33C Offline
                    Cr4z33
                    @Sean module looks loaded correctly, but it is not reacting to my claps?
                    I see no evidence of reaction if running npm start.
                    I have used the same device like in MMM-Hotwords.
                    		module: "MMM-Clap",
                    		position: "bottom_left",
                    		disabled: false,
                    				detector: {
                    						recordDevice: null,
                    		commands: {
                    				"MODE_DEFAULT": {
                    							"2": {
                    								shellExec: {
                    										exec: "echo on 0 | cec-client -s -d 1"
                    								restart:true,
                    Still running everything in my Rpi 3 B+ of course. ;)
                    • ? Offline
                      @smarthome
                      Sorry for my Poor English. I cannot still get your words.
                      Tell me your scenario or use case for using CLAP_RESUME/CLAP_PAUSE. these both might be used when Mic should be released or re-obtained for other module’s usage. In other cases, usually you don’t need to care these.
                      Why do you need and with which modules?
                      • ? Offline
                        @Cr4z33
                        Show me the log. If works; Belows should be shown.
                        Connecting socket for: MMM-Clap
                        Launching application.
                        [CLAP] Starts.
                        • Cr4z33C Offline
                          Cr4z33 @Guest
                          @Sean
                          npm start
                          > magicmirror@2.8.0 start /home/pi/MagicMirror
                          > sh run-start.sh
                          Starting MagicMirror: v2.8.0
                          Loading config ...
                          Loading module helpers ...
                          Module helper loaded: MMM-Clap
                          Module helper loaded: MMM-WatchDog
                          Module helper loaded: MMM-Remote-Control
                          Module helper loaded: MMM-RTSPStream
                          Module helper loaded: MMM-AssistantMk2
                          Module helper loaded: MMM-Spotify
                          Module helper loaded: MMM-DarkSkyForecast
                          Module helper loaded: MMM-PushBulletNotifications
                          Module helper loaded: MMM-Hotword
                          All module helpers loaded.
                          You're using a full whitelist configuration to allow for all IPs
                          Server started ...
                          Connecting socket for: MMM-WatchDog
                          Starting module helper: MMM-WatchDog
                          Connecting socket for: MMM-Remote-Control
                          Starting node helper for: MMM-Remote-Control
                          Connecting socket for: MMM-RTSPStream
                          PM2: Stopping all OMXPlayer Streams...
                          Starting module: newsfeed
                          Connecting socket for: MMM-AssistantMk2
                          Connecting socket for: MMM-Spotify
                          [SPOTIFY_AUTH] Token is fresh.
                          Connecting socket for: MMM-DarkSkyForecast
                          ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                          Connecting socket for: MMM-PushBulletNotifications
                          Connecting socket for: MMM-Hotword
                          [HOTWORD] MMM-Hotword starts
                          WatchDog started. Maximum timeout: 10s.
                          Create new news fetcher for url: https://eur.fxexchangerate.com/usd.xml - Interval: 300000
                          Create new news fetcher for url: https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml - Interval: 300000
                          Create new news fetcher for url: https://www.ansa.it/sito/notizie/mondo/mondo_rss.xml - Interval: 300000
                          Create new news fetcher for url: https://feeds.hwupgrade.it/rss_hwup.xml - Interval: 300000
                          Create new news fetcher for url: http://feeds.feedburner.com/hd-blog?format=xml - Interval: 300000
                          Create new news fetcher for url: https://www.tomshw.it/feed/ - Interval: 300000
                          Create new news fetcher for url: https://www.punto-informatico.it/feed/ - Interval: 300000
                          Create new news fetcher for url: http://www.lecceprima.it/rss/ - Interval: 300000
                          Create new news fetcher for url: http://www.galatina.it/rss.xml - Interval: 300000
                          [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                          [AMK2] Recipe is loaded: reboot.js
                          [AMK2] Recipe is loaded: screen_onoff.js
                          [AMK2] Recipe is loaded: shutdown.js
                          [MMM-PushBulletNotifications][Info] 12:24:12.329 - START received
                          [CLAP] Starts.
                          [AMK2] Temporal storage directory is clearing.
                          [HOTWORD] begins.
                          [HOTWORD] Detector starts listening.
                          [MMM-PushBulletNotifications][Info] 12:24:15.355 - PushBullet connected
                          ^CShutting down server...
                          Stopping module helper: MMM-Clap
                          Stopping module helper: MMM-WatchDog
                          Shutting down MMM-RTSPStream streams that were using vlc
                          Stopping module helper: updatenotification
                          Stopping module helper: newsfeed
                          Stopping module helper: MMM-AssistantMk2
                          Stopping module helper: MMM-Spotify
                          Stopping module helper: MMM-DarkSkyForecast
                          Stopping module helper: MMM-PushBulletNotifications
                          Stopping module helper: MMM-Hotword
                          [HOTWORD] Final Result: { detected: false }
                          [HOTWORD] begins.
                          • ? Offline
                            @Cr4z33
                            You are using MMM-Clap & MMM-Hotword at a same time. Have you 2 mics?
                            Or you should control taking & releasing the mic between modules. I don’t recommend.
                            • Cr4z33C Offline
                              Cr4z33 @Guest
                              @Sean I’ve got one USB mic.
                              Sorry I am not sure you gave me the solution. :smiling_face_with_open_mouth_cold_sweat:
                              Say again?
                              • ? Offline
                                @Cr4z33
                                MMM-Clap and MMM-Hotword will compete each other to take one mic. I think you’d better to use just one module. At least one module at a time. You can make juggling with CLAP_RESUME, CLAP_PAUSE, HOTWORD_RESUME, HOTWORD_PAUSE to confirm only one module uses a mic at a time. But too complex. not recommended.
                                  smarthome @Guest
                                  @Sean
                                  The scenario is:
                                  Step 1: Clap action
                                  Step 2: Clap sound detected, MMM Clap send output notification to MMM Page Selector while Mic still not released yet
                                  Step 3: MMM Page Selector receive input notification then change page
                                  Step 4: MMM Page Selector sends output notification CLAP_PAUSE to MMM Page Selector to release the MIC and waitting for next clap sound
                                  • ? Offline
                                    @smarthome said in MMM-Clap:
                                    Step 1: Clap action
                                    In this real usage, You don’t need to release mic at all. MMM-Page-Selector doesn’t use any mic. So why do you need to release mic for changing pages? Mic Releasing is needed only when your other module wants to use the same Mic (like MMM-AssistantMk2). Unless you set restart:false, MMM-Clap will be restarted automatically after detection regardless other module’s job.
                                    And If you REALLY want to have a feature - sending some specific notification from specific module -, request module creator to do so. But with this case, I don’t think it needs.
                                    • ? Offline
                                      A Former User @Guest
                                      @smarthome
                                      @Sean said in MMM-Clap:
                                      Fortunately(???) There is already a solution about this;
                                      As far as I know MMM-Page-Selector could emit PAGE_CHANGED notification.
                                      All you need is to translate that notification to what you need. And MMM-NotificationTrigger module could do that job.
                                      • Cr4z33C Offline
                                        Cr4z33 @Guest
                                        @Cr4z33
                                        Oh now I got it.
                                        Thanks however I will then keep using MMM-Hotwords.
                                        Too precious for my voice command needs hehe. 😁
                                          smarthome @Guest
                                          @Sean
                                          I’d already, but didn’t work
                                          		  module: "MMM-NotificationTrigger",
                                          		  //This module works in Background, so you don't need to describe `position`.
                                          			useWebhook: false, // If you want to activate webhook as Notification emitter, set true. (eg. IFTTT)
                                          			triggers:[ // Array of triggers.
                                          				trigger: "PAGE_CHANGED", //REQUIRED
                                          				triggerSenderFilter: (sender) => { //OPTIONAL should return true or false
                                          				  if (sender == "MMM-Page-Selector") {
                                          					return true
                                          				  return false
                                          				triggerPayloadFilter: (payload) => { //OPTIONAL should return true or false
                                          				  if (typeof payload.value !== 'undefined' && payload.value > 0) {
                                          					return true
                                          				  return false
                                          				fires: [ // Array of fires. You can enable multi-firing with one trigger.
                                          					fire:"CLAP_RESUME", //REQUIRED
                                          					payload: (payload) => { //OPTIONAL. transform received payload to what your target module wants.
                                          					  return payload
                                          		 //           delay: 1000, //OPTIONAL, if this is set, your outgoing notification will be fired after delay.
                                          		 //           exec: "ls -l" //OPTIONAL, if exists, this script will be executed, and the result will be returned with "OUTGOING_NOTIFICATION_RESULT" and payload.  Can also be specified as a function which accepts the payload as an argument and returns the command to execute.
                                          • ? Offline
                                            @smarthome
                                            Repeating again; Why do you need CLAP_RESUME/CLAP_PAUSE on page changing? Without them the module will work. I’m a little embarrassed to understand why you need it.
