    mmm-nest-status unresponsive after 12hours
    34 Posts 4 Posters 17.9k Views 4 Watching
      dazza120 @sdetweil
      @sdetweil it’s literally just the seconds of the time I’m seeing which I might try to stop not seen any Nest process but I did restart it before this so that error has likely gone, as soon as it happens again I will dev console and check thank you
        rts58
        Based upon the display, it stopped on me last night. I was running mm serveronly so I could see the dev output in browser. I couldn’t find any errors. It could have stopped when scheduler is set to hide all modules. I did see this in the console after this mornings schedule to show modules:
        TypeError: Cannot read property 'statusCode' of undefined
            at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:20:25)
            at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
            at emitOne (events.js:116:13)
            at Request.emit (events.js:211:7)
            at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
            at ClientRequest.emit (events.js:211:7)
            at TLSSocket.socketErrorListener (_http_client.js:401:9)
            at TLSSocket.emit (events.js:211:7)
        In the past I don’t think I ever had a conflict between scheduler and nest status.
          sdetweil @rts58
          @rts58 cool… I just pushed a change to my repo for this error…
          if using my repo version, git pull to get the updated node_helper.js
          R D 2 Replies Last reply Reply Quote 0
            rts58 @sdetweil
            @sdetweil just got the update, I’ll let you know what I find. Thanks!
              dazza120 @sdetweil
              @sdetweil updated! 👍🏾
                rts58
                It’s been 24 hours and still working fine! Thanks!
                • C Offline
                  costascontis
                  is the issue solved?How?
                    sdetweil @costascontis
                    @costascontis bug in the original repo, use mine
                    git clone https://github.com/sdetweil/mmm-nest-status
                    C 1 Reply Last reply Reply Quote 1
                    • C Offline
                      costascontis @sdetweil
                      @sdetweil thanx mate.I use your repo ,it works fine but after a day or so i get a "Nest API Error:[object Object]
                        @costascontis i just added some code to display the contents of that error object,
                        do a git pull in the module folder and restart the mirror app.
                        • C Offline
                          @sdetweil so the error is
                          Nest API Error:{"code":"ECONNRESET","path"null,"host":"firebase-apiserver38-tah01-iad01.dapi.production.nest.com","port":"9553"}
                            @costascontis ain’t that helpful!
                            • C Offline
                              @sdetweil this is the error appearing at my MM screen after 6-8 hours.What else can i do to help?
                                @costascontis the nest server is having some trouble… I don’t know what… maybe change the timeout longer? I don’t know anything about the api. I just fixed a bug in the error handling
