    Temperature MagicMirror (Raspberry)
    4 Posts 3 Posters 1.2k Views 3 Watching
    • N Offline
      Notch
      Hello,
      I would be interested to know if any of you can see the temperature of the PI and how high your temperature is in continuous operation. Or what kind of cooling you use.
      My temperature is permanently at 50-55 degrees.
      • mumblebajM Offline
        mumblebaj Module Developer @Notch
        @Notch Mine runs at between 55 and 65 degrees. I use the MMM-SystemStats module. works fine for me. I am only using a heatsink.
        • N Offline
          Notch
          OK, then that seems to be normal with the temperature. Had something to think about the thing to run continuously.
          • evroomE Offline
            evroom
            I have a Pi 3 in a plastic housing and with a fan, running at 46,5 degrees celsius
            And I have one in an all aluminum housing without a fan, running at 38,5 degrees celsius.
            It can be the location that makes a difference, but I would say the housing makes the biggest difference.
            Very pleased with the all aluminum.
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
