    MMM-TelegramBot error
    13 Posts 3 Posters 3.9k Views 3 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      Last login: Sat Aug  3 21:49:39 on ttys000
      Patricks-Mini:~ patrickhahn$ cd MagicMirror
      Patricks-Mini:MagicMirror patrickhahn$ cd modules
      Patricks-Mini:modules patrickhahn$ cd MMM-TelegramBot
      Patricks-Mini:MMM-TelegramBot patrickhahn$ npm install
      Unhandled rejection Error: EACCES: permission denied, mkdir '/Users/patrickhahn/.npm/_cacache/index-v5/a6/60'
      npm ERR! cb() never called!
      npm ERR! This is an error with npm itself. Please report this error at:
      npm ERR!     <https://npm.community>
      npm ERR!     /Users/patrickhahn/.npm/_logs/2019-08-03T20_08_18_484Z-debug.log
      can anybody help me ?
      S 2 Replies Last reply
        A Former User @Stoffbeuteluwe
        @Stoffbeuteluwe
        It works on OSX well (Basically all my magicmirror modules were developed on MacBookPro)
        I agree to @sdetweil . You might have made a mistake to use sudo on making your environment.
        To solve this problem
        • delete your npm cache
        • reset the permissions of your /Users/patrickhah/.npm
        https://docs.npmjs.com/getting-started/fixing-npm-permissions
        https://docs.npmjs.com/troubleshooting/try-clearing-the-npm-cache
        Or try this;
        sudo npm cache clean -f
        StoffbeuteluweS 2 Replies Last reply
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe looks like u ran sudo npm install which marked all the folders as owned by root…
          fix
          from the MagicMirror folder do
          sudo chown -R patrickhahn .
          then redo your npm install for that module
          StoffbeuteluweS 1 Reply Last reply
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @sdetweil
            @sdetweil sorry not working
              @Stoffbeuteluwe what does it say?
              • StoffbeuteluweS
                @sdetweil it says the same
                  @Stoffbeuteluwe ok, try this in the MagicMirror folder
                  sudo chown -R patrickhahn *.*
                  • StoffbeuteluweS
                    it is still the same error
                      @Stoffbeuteluwe sorry, dumb
                      in the users home folder, not from MagicMirror…
                      my mistake
                      cd ~
                      • StoffbeuteluweS
                        @sdetweil it is the same…I will try again tomorrow thank you
                        • StoffbeuteluweS
                          @sdetweil now I have a new install off MM but still the same problem. Maybe the module doesn’t work on Mac
                          ? 1 Reply Last reply
                            @Stoffbeuteluwe
                            Or try this;
                            • StoffbeuteluweS
                              Stoffbeuteluwe Project Sponsor @Guest
                              @Sean what I doing wrong when installing magic mirror or npm
                              -I do the manual install…from MM site
                              -I download node js and install
                              • I install pm2
                              • than I install modules
                              • StoffbeuteluweS
                                @Sean works thank you 🙏
