    Add JS Code to the Mirror
    33 Posts 5 Posters 17.8k Views 5 Watching
      stro
      i have the following problem, i want to show the current playing song from mopidy, so i install the MMM-MPD module, but it shows me only a play button, nothing else. So i try another way and i found this code in the web:
      https://pastebin.com/7e40507n
      Now my problem is, when i open the file:
      file:///home/pi/MagicMirror/modules/test/mopidy.html
      it shows exactly that output i want to see.
      But if i open:
      localhost:8080/modules/test/mopidy.html
      or try to put the code in the index.html it shows me nothing. Can anyone help me to find out, what is blocking the code? Thanks!
        stro
        This post is deleted!
          stro
            sdetweil
            So, u need to change the HTML returned by MMM-MPD to look like the HTML in the file. But only the section that is your real user interface.
            See the getDom() function which would build the html.
              stro
              No, i want to show the current playing Track from mopidy.
              Either by MMM-MPD (i didn‘t get to work)
              Or by the Code i found on the web ( i didn‘t get to work)
                sdetweil @stro
                @stro MagicMirror is a web page.
                It displays html. The modules generate a small section matching their requirements, and mm injects that onto the page in the configured position.
                The module can get it’s data from anywhere. API, file system, database.
                You have an API, which returns data, not html. Some code has to convert the data into displayable html
                  stro
                  @sdetweil thanks for helping me.
                  I have the code (pastebin) who put the data, i‘m looking for, in a HTML Output. If i open the html file like this
                  everything is okay.
                  But if open this HTML File with the Mirrorpath like this:
                  It shows me nothing. And i wonder why.
                    sdetweil @stro
                    @stro open the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors
                      stacywebb
                      Check your
                      mopidy.conf
                      located at:
                      ~/.config/mopidy/mopidy.conf
                      Look for this section:
                      [http]
                      enabled = true
                      hostname = 127.0.0.1
                      port = 6680
                      static_dir =
                      zeroconf = Mopidy HTTP server on $hostname
                      allowed_origins =
                      csrf_protection = true
                      Take note of the hostname part.
                      If your’s looks like the above instead of using localhost in the url, use the ip address or host name of the mirror.
                      Examples:
                      mirror.local:8080/modules/test/mopidy.html
                      or
                      10.x.x.x:8080/modules/test/mopidy.html
                      I tested the code you posted on pastebin and it works as expected for me.
                      Only tested using the hostname of the Mirror from external browser. Not locally on the machine.
                        stro
                        I was able to solve that problem.
                        MPD port was double busy. Apparently 2 instances of Mopidy were running.
                        Now the module MMM-MPD runs under a few specials:
                        During the installation the folder name has to be changed according to the config file.
                        The config file value maxRows must not be 0!
                        The display will only update after a song change!
                        It was hard to find this specifics, but I thank everyone for the help!
                        • L Offline
                          Leobo
                          Thank You @stro, This work great. Im rename folder MMM-MPD to mod_client and move to MagicMirror module, From MagicMirror/module/mpd_client npm install and work.
                            dnj0104 @Leobo
                            @Leobo said in Add JS Code to the Mirror:
                            Something like this happens to me, but my module is from user coderpussy @github , pretty new fork, maybe I got some failure from moodeaudio devs, but I dont think, so anyway here is some of my errors.
                            if change folder name mmm-mpd to mpd_client errors in MM startup:
                            alerts in MagicMirror startup:
                            WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/mpd_client/node_helper.js:4:18)
                                at Module._compile (internal/modules/cjs/loader.js:786:30)
                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                at Module.load (internal/modules/cjs/loader.js:645:32)
                                at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                at Module.require (internal/modules/cjs/loader.js:685:19)
                                at require (internal/modules/cjs/helpers.js:16:16)
                                at loadModule (/home/pi/MagicMirror/js/app.js:134:17)
                                at loadNextModule (/home/pi/MagicMirror/js/app.js:169:5)
                                at /home/pi/MagicMirror/js/app.js:171:6
                            change folder name from mmm-mpd to mpd-client:
                            Result: No errors in MM-startup but mpd-module does not start.
                            **Looking for errors in MM-dev tools with folder named to mpd-module>**
                            Errors:
                            Load script: modules/mpd_client//mpd_client.js
                            :8080/modules/mpd_cl…nt//mpd_client.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                            loader.js:186 Error on loading script: modules/mpd_client//mpd_client.js
                            module in mm-config array looks like
                            this.
                            		module: "mpd_client",
                            		position: "top_right",	// This can be any of the regions.
                            			hostname:"mpd@moodeaudio@rpi3b+=IPnumber)",
                            			port:6600
                              sdetweil @dnj0104
                              @dnj0104 there is probably more to the error message this also happens when there is some library required by a module not found at startup
                              u can also run
                              npm run config:check
                              to review any syntax errors in the config.js file
                                dnj0104 @sdetweil
                                @sdetweil said in Add JS Code to the Mirror:
                                in magicmirror/modules
                                or in magicmirror/modules/mpd-module ?
                                Thinks the whole module has to be rebuilt…
                                  sdetweil @dnj0104
                                  @dnj0104 in MagicMirror
                                    dnj0104 @sdetweil
                                    then I got
                                    [2020-10-23 23:46:08.836] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                                    [2020-10-23 23:46:09.049] [INFO]   Your configuration file doesn't contain syntax errors :)
                                      sdetweil @dnj0104
                                      @dnj0104 ok, so the error that causes the default config to load is caused by some other problem.
                                      missing module, or some other failure
                                      can u show the MM startup messages (from the window where you do npm start)
                                      a module consists of the folder name
                                      MMM-MPD
                                      and its main js file
                                      MMM-MPD.js
                                      and inside MMM-MPD.js is the module register statement
                                      Module.register("MMM-MPD", {
                                      and in config.js
                                           module: 'MMM-MPD',
                                      this causes MM to look for the folder, filename and file contents in that order
                                      SO, it SOUNDS like from a prior post, that the REAL name is
                                      mod_client
                                      (so there must be the right folder name, file name and file contents of
                                      mod_client
                                      if so, you can rename the folder (mv is the rename command on linux)
                                      then in config.js you need
                                        module:'mod_client',
                                      see the topic ‘How to add modules’ in my signature
                                        dnj0104
                                        mod_client
                                        errors folder and file config.js (mmm-mpd) renamed to mod:
                                        [2020-10-24 00:03:42.600] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/mod_client/node_helper.js:4:18)
                                        [2020-10-24 00:03:42.601] [LOG]    Loading module helpers ...
                                        [2020-10-24 00:03:42.602] [LOG]    No helper found for module: alert.
                                        [2020-10-24 00:03:42.603] [LOG]    Initializing new module helper ...
                                        [2020-10-24 00:03:42.604] [LOG]    Module helper loaded: updatenotification
                                        [2020-10-24 00:03:42.605] [LOG]    No helper found for module: clock.
                                        [2020-10-24 00:03:42.616] [LOG]    Initializing new module helper ...
                                        [2020-10-24 00:03:42.617] [LOG]    Module helper loaded: calendar
                                        [2020-10-24 00:03:42.618] [LOG]    No helper found for module: .
                                        [2020-10-24 00:03:42.619] [LOG]    No helper found for module: currentweather.
                                        [2020-10-24 00:03:42.620] [LOG]    No helper found for module: weatherforecast.
                                        [2020-10-24 00:03:42.621] [LOG]    Initializing new module helper ...
                                        [2020-10-24 00:03:42.621] [LOG]    Module helper loaded: newsfeed
                                        [2020-10-24 00:03:42.623] [ERROR]  App threw an error during load
                                        [2020-10-24 00:03:42.625] [ERROR]  ReferenceError: NodeHelper is not defined
                                        [2020-10-24 00:03:42.627] [ERROR]  Whoops! There was an uncaught exception...
                                        [2020-10-24 00:03:42.628] [ERROR]  ReferenceError: NodeHelper is not defined
                                        ------result---- dark—screen electron just showed black----------
                                        roll back, Folder named to mod-client and in config.js and mpd_client.js to mod_client.
                                        Result; electron start with no error all my modules shows, but not mod_client aka mpd_client
                                          sdetweil @dnj0104
                                          @dnj0104 what MM version are you running on? this problem was fixed in 2.10
                                          do this
                                          from the MM folder
                                          cd ~/MagicMirror
                                          git checkout modules/node_modules/node_helper/index.js
                                            dnj0104
                                            I got version 20.13.0
                                            from your git command i get output
                                            pi@raspberrypi:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                                            error: pathspec 'modules/node_modules/node_helper/index.js' did not match any file(s) known to git
