SOLVED Need help please MMM-dropbox error
@Stoffbeuteluwe ok at first we can try to handle the Dropbox problem
@Stoffbeuteluwe said in Need help please MMM-dropbox error:
is a lock on Remote Control it say a other module have locked the current weather module
no idea, never seen this
he has a bad design,
he starts a timer, with a 0 delay
initialLoadDelay int 0 How long to delay the initial load (in ms)and so it calls to get data BEFORE it initializes the node helper…
in your config.js config {} section for this module add
initialLoadDelay: 5000,
and it says if the token is not specified, present and error message,
if (this.config.token === '') { this.errMsg = 'Please add your Dropbox token to the MagicMirror config.js file.';
but it still calls the node helper to get data, which then crashes with the error u see
@sdetweil sometimes it works but not very often
@sdetweil I will try a new token…thanks Sam
