    MMM-BackgroundSlideshow
    30 Posts 4 Posters 12.8k Views 4 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe not with my code, no
      the original code does fill the screen if u set the max height and width to the screen size
      img.style.maxWidth = this.config.maxWidth;
      img.style.maxHeight = this.config.maxHeight;
      StoffbeuteluweS 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil Thank you Sam 😀🙏
          @sdetweil hi Sam can you help me again I have tried a lot but no luck…my screensize is
          width: 1080
          high: 1920
          I don’t know how to set it the right way
          Thanks 🙏
            @Stoffbeuteluwe are u portrait, not landscape? original or mine?
            it should work, but ugly
              @sdetweil Portrait
                @Stoffbeuteluwe oops. the width/height is from the imagesSlideshow
                this module only supports
                backgroundSize	The sizing of the background image. Values can be:
                cover: Resize the background image to cover the entire container, even if it has to stretch the image or cut a little bit off one of the edges.
                contain: Resize the background image to make sure the image is fully visible
                Example: 'contain'
                Default value: 'cover'
                This value is OPTIONAL
                  sdetweil
                  also, how are you rotated? physical or CSS?
                  module does
                  			div1.style.transform="rotate(0deg)";
                  then adjusts if different
                  var Orientation = EXIF.getTag(this, "Orientation");
                  				if (Orientation != null) {
                    @sdetweil I rotate with settings on my Mac
                    Settings , Monitor , Rotation 90
                      @Stoffbeuteluwe hm… on my virtual mac, landscape it looks ok… (backgroundsize: ‘contain’)
                      i don’t see that monitor settings option on my catalina mac vm…
                      • H Offline
                        hootzter
                        @sdetweil thank you very much. I got I working with MMM-ImagesPhotos (took your config + enhanced swap size). My pictures are displayed now :).
                        Is there a chance to auto-rotate to landscape if picture orientation is portrait? Or should I use another module to do this (which one)?
                        Best regards
                        hootzter
