    Mirror goes black after hours
    11 Posts 3 Posters 4.8k Views 4 Watching
    • T Offline
      tbs86
      Hello.
      So ever since ive had my mirror the mirror will always go blank after about 8-10 hours of being on. I did have a notification about updating Magicmirror software which i did and it did not fix the issue. then did some research about updating node.js which i did. None of these have fixed the mirror from going blank after several hours. When the mirror goes blank i am able to move the mouse around and see the cursor. Only way to fix it is to quit the program and restart it. Has anybody had this issue or know a work around to stop it going blank on me?
        sdetweil @tbs86
        @tbs86 ia this on a pi?
        I had to do this
        https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
        and reboot
        to stop my frequent black screens.
        then I added this module to record more info
        https://github.com/shbatm/MMM-Logging
        T 2 Replies Last reply Reply Quote 0
        • T Offline
          tbs86 @sdetweil
          Yes pi3 will try once i am home thanks for the help
          • T Offline
            tbs86 @sdetweil
            @sdetweil did what you said pie ran over night. Went to work and it was blank again. I think it’s something do to with one of my modules Google maps. I saw the command prompt and saw a error I believe.
              sdetweil @tbs86
              @tbs86 ok, one step in the right direction
              • T Offline
                tbs86 @sdetweil
                @sdetweil anyway to confirm its the module?
                  sdetweil @tbs86
                  @tbs86 are you using pm2?
                  if so, look in the ~/.pm2/logs folder MagicMirror.error.log
                  also the heavy way.
                  edit the config and add
                  disabled: true,
                  to the module you think it is, and then restart
                  • T Offline
                    tbs86
                    Sorry still new to this. Disable the module and see if this fixed the issue?
                      sdetweil @tbs86
                      @tbs86 yes, that is another way…
                      • T Offline
                        tbs86
                        Ok will try and report back
                        • buzzkcB Offline
                          buzzkc
                          If it was the MMM-GoogleMapsTraffic module that you’re seeing errors with, I had to comment out the console.log line noted in this commit, which fixed the black screen issue I was having. https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24/commits/90f51f6f7a155241a4371106ea3ca899b20a7380
                          Darren
                          My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
