    Problem when installing MagicMirror on Raspbian Buster RPB3+
    26 Posts 4 Posters 13.2k Views 4 Watching
      sdetweil @thomaslc
      @thomaslc sure… and the output of
      pm2 logs --lines=100
      my email is the same userid as here on gmail…
      and there is some startup problem… cause pm2 thinks the mirror is running,
      and then u do npm start AGAIN… but you should get output some output…
      • B
        bobwilliams @sdetweil
        @sdetweil Yesterday I installed pi 3 B + on the raspberry, it was installed without problems.
          sdetweil @bobwilliams
          @bobwilliams thanks… your original problem was with update, which is where i see a problem i need to correct
          • B
            @sdetweil on pi zero also decided … so everything is in order …
              @bobwilliams yes, install is good… update still has a problem…
              • B
                @sdetweil thank you for your hard work
