    Issues with the French translation in MMM-rfacts
    5 Posts 2 Posters 1.3k Views 2 Watching
    • C
      chassain 0
      hello everybody,
      is there some people having problems to translate the result of module MMM rfacts? many times error and return to english.
      • C
        chassain 0 @chassain 0
        @chassain-0
        It’s ok after npm install -g npm@latest and npm install -g n
        n stable
        thanks…i thought sudo apt-get update and upgrade was enough
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @chassain 0
          @chassain-0
          I just installed this module. It seems to work fine with french translation.
          Have you installed the dependencies?
          npm install in the MMM-rfacts directory.
          Is the language set correctly in your config.js file?
          language: "fr",
          • C
            chassain 0
            Hello Myke1,
            It was good one month ago but now, after a new npm install i have error :
            (node:1031) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            npm WARN package.json json-schema@0.2.3 No license field.
            npm WARN package.json punycode@2.1.1 punycode is also the name of a node core module.
            npm ERR! Error: Method Not Allowed
            npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
            npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
            npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
            npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
            npm ERR! If you need help, you may report this entire log,
            npm ERR! including the npm and node versions, at:
            npm ERR! http://github.com/npm/npm/issues
            npm ERR! System Linux 4.19.68-v7+
            npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
            npm ERR! cwd /home/pi/MagicMirror/modules/MMM-rfacts
            npm ERR! node -v v8.11.1
            npm ERR! npm -v 1.4.21
            npm ERR! code E405
            npm ERR!
            npm ERR! /home/pi/MagicMirror/modules/MMM-rfacts/npm-debug.log
            npm ERR! not ok code 0
            • C
              @chassain-0
              n stable
              • Mykle1M
                @chassain-0
                Yes, being down level node and npm makes MM unhappy at times. Glad you got things working.
