    Update to v2.9.0 fail
    48 Posts 3 Posters 20.7k Views 3 Watching
      bdream
      As I get informed about new update available on my MagicMirror² I tried
      git pull && npm install
      and got
      Aktualisiere a31546b..500147e
      error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
      überschrieben werden:
              package-lock.json
      Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen.
      Abbruch
      Sorry for german error message :winking_face: which mean I have to commit my? changes on package-lock.json
      I don’t know what and how and even why :face_screaming_in_fear:
      I have no clue about any change I made on package-lock.json
      @sdetweil I saw your post link text but don’t know if this is for Raspberry alsow and if I should try this.
      I’m a little afraid killing my installation.
      cheers, bdream
        sdetweil @bdream
        @bdream u should use my script…
        instructions here
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
          bdream
          I tried u script but get further message update available even I restarted mm
          pm2 start mm
          the upgrade log here
          Upgrade started - Mi Okt 16 14:38:38 CEST 2019
          doing test run = true
          downloading dumpactivemodules script
          saving custom.css
          not english or locale not set, set git alias
          remote name = origin
          upgrading from version 2.8.0 to 2.9.0
          fetching latest revisions
          current branch = master
          no files different from github version
          test merge result rc='' , if empty, no conflicts
          skipping merge, only test run
          processing dependency changes for active modules with package.json files
          processing for module MMM-Carousel please wait
          skipped processing for MMM-Carousel, doing test run
          processing complete for module MMM-Carousel
          processing for module MMM-PublicTransportHafas please wait
          skipped processing for MMM-PublicTransportHafas, doing test run
          processing complete for module MMM-PublicTransportHafas
          restoring custom.css
          removing git alias
          Upgrade ended - Mi Okt 16 14:38:45 CEST 2019
          Upgrade started - Mi Okt 16 14:41:56 CEST 2019
          user requested to apply changes
          doing test run = false
          saving custom.css
          executing merge, apply specified
          merge result rc= 1
           error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
          there were merge errors
          you should examine and resolve them
          using the command git log --oneline --decorate
          a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
          removing git alias
          Upgrade ended - Mi Okt 16 14:41:58 CEST 2019
          cheers, bdream
            sdetweil @bdream
            @bdream fun… can u show me the results of
            alias git='LANGUAGE=en_US.UTF-8 git'
            git status
            unalias git >/dev/null
            thanks…
            I had also changed the messaging to english… surprised at the german message…
              bdream
              @sdetweil seems there is a deeper problem!?!
              pi@MagicMirror:~ $ git status
              fatal: not a git repository (or any of the parent directories): .git
              what does this mean please?
              cheers, bdream
                sdetweil @bdream
                @bdream u need to be in the MagicMirror folder to do those commands
                i set an alias for git to use english messages
                then execute a git command, with english output
                then remove the alias, so back to your configured language
                  bdream
                  @sdetweil SORRY!
                  pi@MagicMirror:~/MagicMirror $  git status
                  On branch master
                  Your branch is behind 'origin/master' by 2715 commits, and can be fast-forwarded.
                    (use "git pull" to update your local branch)
                  Changes not staged for commit:
                    (use "git add <file>..." to update what will be committed)
                    (use "git checkout -- <file>..." to discard changes in working directory)
                          modified:   css/custom.css
                          modified:   package-lock.json
                  Untracked files:
                    (use "git add <file>..." to include in what will be committed)
                          core
                          installers/dumpactivemodules.js
                          installers/pm2_MagicMirror_new.json
                          mm.sh
                          nohup.out
                  no changes added to commit (use "git add" and/or "git commit -a")
                  cheers, bdream
                    sdetweil @bdream
                    @bdream weird… says code should handle it
                    try this
                    alias
                    git status | grep modified | awk -F: '{print $2}'
                    thanks
                      bdream
                      pi@MagicMirror:~/MagicMirror $  alias
                      alias egrep='egrep --color=auto'
                      alias fgrep='fgrep --color=auto'
                      alias grep='grep --color=auto'
                      alias ls='ls --color=auto'
                      pi@MagicMirror:~/MagicMirror $  alias git='LANGUAGE=en_US.UTF-8 git'
                      pi@MagicMirror:~/MagicMirror $  git status | grep modified | awk -F: '{print $2}'
                         css/custom.css
                         package-lock.json
                      pi@MagicMirror:~/MagicMirror $  unalias git >/dev/null
                      cheers, bdream
                        sdetweil @bdream
                        @bdream weird…
                        can u try the script again? i am recording the output of the git status command, manually it detects the file
                          bdream
                          pi@MagicMirror:~/MagicMirror $   bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
                          update log will be in /home/pi/MagicMirror/installers/upgrade.log
                          saving custom.css
                          cheers, bdream
                            sdetweil @bdream
                            @bdream can u show me the log again
                              bdream
                              Upgrade started - Mi Okt 16 15:22:29 CEST 2019
                              saving custom.css
                              merge result rc= 1
                              removing git alias
                              Upgrade ended - Mi Okt 16 15:22:31 CEST 2019
                              cheers, bdream
                                sdetweil @bdream
                                @bdream said in Update to v2.9.0 fail:
                                there is supposed to be output from the git status command right there ???
                                I just made another tiny log reporting change… one more time please
                                  bdream
                                  saving custom.css
                                  Upgrade started - Mi Okt 16 15:31:26 CEST 2019
                                  saving custom.css
                                  Auf Branch master
                                  Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                                    (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                                  Änderungen, die nicht zum Commit vorgemerkt sind:
                                    (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                    (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                                  	geändert:       css/custom.css
                                  	geändert:       package-lock.json
                                  Unversionierte Dateien:
                                  	core
                                  	css/save_custom.css
                                  	mm.sh
                                  	nohup.out
                                  keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
                                  merge result rc= 1
                                  removing git alias
                                  Upgrade ended - Mi Okt 16 15:31:29 CEST 2019
                                  I’m sorry for german within the log :unamused_face:
                                  cheers, bdream
                                    sdetweil @bdream
                                    that will do it… i search for english ‘modified’, but its not there…
                                    ok, one more time… another reporting change
                                      bdream
                                      Upgrade started - Mi Okt 16 15:38:04 CEST 2019
                                      saving custom.css
                                      Auf Branch master
                                      	%logfile
                                      	core
                                      	css/save_custom.css
                                      	mm.sh
                                      	nohup.out
                                      merge result rc= 1
                                      removing git alias
                                      Upgrade ended - Mi Okt 16 15:38:06 CEST 2019
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream cool… do this
                                        shopt | grep expand
                                        should see this
                                        expand_aliases  on
                                        I bet you see this
                                        expand_aliases  off
                                          bdream
                                          @sdetweil said in Update to v2.9.0 fail:
                                          I bet you see this
                                          expand_aliases off
                                          pi@MagicMirror:~/MagicMirror $   shopt | grep expand
                                          assoc_expand_once       off
                                          direxpand       off
                                          expand_aliases  on
                                          cheers, bdream
                                            sdetweil @bdream
                                            expand_aliases on
                                            yeh, but it didn’t!!
                                            try script again
                                            • 1 / 3
