    Update to v2.9.0 fail
    48 Posts 3 Posters 18.6k Views 3 Watching
      bdream
      @sdetweil said in Update to v2.9.0 fail:
      try script again
      pi@MagicMirror:~/MagicMirror $  bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
      doing test run = false
      update log will be in /home/pi/MagicMirror/installers/upgrade.log
      saving custom.css
      upgrading from version 2.8.0 to 2.9.0
      fetching latest revisions
      there are 2 local files that are different than the master repo
         css/custom.css
         package-lock.json
      any *-lock.json files do not need to be saved
      do you want to save these files for later   (Y/n)?Y
      *** Bitte geben Sie an, wer Sie sind.
      Führen Sie
        git config --global user.email "you@example.com"
        git config --global user.name "Your Name"
      aus, um das als Ihre standardmäßige Identität zu setzen.
      Lassen Sie die Option "--global" weg, um die Identität nur
      für dieses Repository zu setzen.
      fatal: Konnte die E-Mail-Adresse nicht automatisch erkennen ('pi@MagicMirror.(none)' erhalten)
      Kann den aktuellen Zustand des Index nicht speichern
      there were merge errors
      error: Your local changes to the following files would be overwritten by merge:         package-lock.json Please commit your changes or stash them before you merge. Aborting Updating a31546b..500147e
      you should examine and resolve them
      using the command git log --oneline --decorate
      a31546b (grafted, HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
      restoring custom.css
      we stashed a set of files that appear changed from the latest repo versions. you should review them
      Keine Stash-Einträge gefunden.
      see installers/stashed_files for the list
      you can use git checkout stash@{0} -- filename to extract one file from the stash
      or git stash pop to restore them all
      WARNING..
      WARNING.. either will overlay the file just installed by the update
      WARNING..
      custom.css is realy touched by me but should not be affected by updates I thougt.
      Führen Sie
      that says about the git configuration is not correct. But I never configured git on the Pi. Do I need to do?
      The fatal is about the e-mail was not to get detected automaticly. For sure there was never a e-mail configured for nothing at the Pi.
      Index can not be saved.
      Says 'no Stash-entries were found. whatever that mens.
      cheers, bdream
        sdetweil @bdream
        @bdream hang on…
          @sdetweil try this, note just adding another parm
          bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
          also show results of, notice dot in front of filename
          cat ~/.bashrc
            sdetweil @bdream
            @bdream said in Update to v2.9.0 fail:
            prior to this release, custom.css was considered a core file, and was overlayed on updates.
            this release puts in a fix for that… but I save/restore it anyhow
            stash is a place where you can hold modified files, but continue on with your work.
            it requires some setup, but my script is supposed to go that for you
              bdream
              pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" apply
              saving custom.css
              error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden:    package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen. Abbruch Aktualisiere a31546b..500147e
              upgrade.log
              Upgrade started - Mi Okt 16 17:12:12 CEST 2019
              user requested to apply changes
              saving custom.css
              not english or locale not set, set git alias
              alias egrep='egrep --color=auto'
              alias fgrep='fgrep --color=auto'
              alias git='LANGUAGE=en_US.UTF-8 git'
              alias grep='grep --color=auto'
              alias ls='ls --color=auto'
              remote name = origin
              current branch = master
              Auf Branch master
              Ihr Branch ist 2715 Commits hinter 'origin/master', und kann vorgespult werden.
                (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
              Änderungen, die nicht zum Commit vorgemerkt sind:
                (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
              	geändert:       css/custom.css
              	geändert:       package-lock.json
              Unversionierte Dateien:
              	%logfile
              	core
              	css/save_custom.css
              	installers/dumpactivemodules.js
              	installers/pm2_MagicMirror_new.json
              	mm.sh
              	nohup.out
              keine Änderungen zum Commit vorgemerkt (benutzen Sie "git add" und/oder "git commit -a")
              no files different from github version
              test merge result rc='' , if empty, no conflicts
              executing merge, apply specified
              merge result rc= 1
              removing git alias
              Upgrade ended - Mi Okt 16 17:12:14 CEST 2019
              pi@MagicMirror:~/MagicMirror $  cat ~/.bashrc
              # ~/.bashrc: executed by bash(1) for non-login shells.
              # see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
              # for examples
              # If not running interactively, don't do anything
              case $- in
                  *i*) ;;
                    *) return;;
              esac
              # don't put duplicate lines or lines starting with space in the history.
              # See bash(1) for more options
              HISTCONTROL=ignoreboth
              # append to the history file, don't overwrite it
              shopt -s histappend
              # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
              HISTSIZE=1000
              HISTFILESIZE=2000
              # check the window size after each command and, if necessary,
              # update the values of LINES and COLUMNS.
              shopt -s checkwinsize
              # If set, the pattern "**" used in a pathname expansion context will
              # match all files and zero or more directories and subdirectories.
              #shopt -s globstar
              # make less more friendly for non-text input files, see lesspipe(1)
              #[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
              # set variable identifying the chroot you work in (used in the prompt below)
              if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
                  debian_chroot=$(cat /etc/debian_chroot)
              fi
              # set a fancy prompt (non-color, unless we know we "want" color)
              case "$TERM" in
                  xterm-color|*-256color) color_prompt=yes;;
              esac
              # uncomment for a colored prompt, if the terminal has the capability; turned
              # off by default to not distract the user: the focus in a terminal window
              # should be on the output of commands, not on the prompt
              force_color_prompt=yes
              if [ -n "$force_color_prompt" ]; then
                  if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
                      # We have color support; assume it's compliant with Ecma-48
                      # (ISO/IEC-6429). (Lack of such support is extremely rare, and such
                      # a case would tend to support setf rather than setaf.)
                      color_prompt=yes
                  else
                      color_prompt=
                  fi
              fi
              if [ "$color_prompt" = yes ]; then
                  PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w \$\[\033[00m\] '
              else
                  PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
              fi
              unset color_prompt force_color_prompt
              # If this is an xterm set the title to user@host:dir
              case "$TERM" in
              xterm*|rxvt*)
                  PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
              esac
              # enable color support of ls and also add handy aliases
              if [ -x /usr/bin/dircolors ]; then
                  test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
                  #alias dir='dir --color=auto'
                  #alias vdir='vdir --color=auto'
              fi
              # colored GCC warnings and errors
              #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
              # some more ls aliases
              #alias ll='ls -l'
              #alias la='ls -A'
              #alias l='ls -CF'
              # Alias definitions.
              # You may want to put all your additions into a separate file like
              # ~/.bash_aliases, instead of adding them here directly.
              # See /usr/share/doc/bash-doc/examples in the bash-doc package.
              if [ -f ~/.bash_aliases ]; then
                  . ~/.bash_aliases
              fi
              # enable programmable completion features (you don't need to enable
              # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
              # sources /etc/bash.bashrc).
              if ! shopt -oq posix; then
                if [ -f /usr/share/bash-completion/bash_completion ]; then
                  . /usr/share/bash-completion/bash_completion
                elif [ -f /etc/bash_completion ]; then
                  . /etc/bash_completion
                fi
              fi
              cheers, bdream
                sdetweil @bdream
                @bdream what a battle!
                in the short term, erase package-lock.json
                also show me output of
                echo $LC_ALL
                  bdream
                  done!
                  seems update is working now :grinning_face:
                  saving custom.css
                  updating MagicMirror runtime, please wait
                  > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                  > node install.js
                  Downloading tmp-5207-1-SHASUMS256.txt-3.0.13
                  [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                  > magicmirror@2.9.0 install /home/pi/MagicMirror
                  > cd vendor && npm install
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  audited 220 packages in 12.241s
                  found 5 vulnerabilities (4 low, 1 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                  > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                  We'll remove from the repository the css/custom.css
                  This script apply git update-index --skip-worktree css/custom.css
                  rm 'css/custom.css'
                  MagicMirror installation successful!
                  > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                  > cd fonts && npm install
                  audited 1 package in 1.629s
                  found 0 vulnerabilities
                  npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                  added 173 packages from 113 contributors, removed 132 packages, updated 181 packages, moved 1 package and audited 3475 packages in 1071.546s
                  found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                  processing dependency changes for active modules with package.json files
                  processing for module MMM-Carousel please wait
                  audited 859 packages in 17.666s
                  found 2 high severity vulnerabilities
                  processing complete for module MMM-Carousel
                  processing for module MMM-PublicTransportHafas please wait
                  audited 41 packages in 2.153s
                  processing complete for module MMM-PublicTransportHafas
                  audited 41 packages in 3.251s
                  audited 41 packages in 3.956s
                    pm2 start mm
                  …and it looks GOOD! :rolling_on_the_floor_laughing:
                  It’s great after such a … work? … getting it solved.
                  Thank you sooo much. On my own I would install from scatch :frowning_face: and this is nothing I can bring to my family.
                  and here you asked
                  pi@MagicMirror:~/MagicMirror $  echo $LC_ALL
                  de_DE.UTF-8
                  would say this is one of the first thing I do installing Raspian :grimacing_face:
                  cheers, bdream
                    sdetweil @bdream
                    de_DE.UTF-8
                    bingo… things you learn!..
                    LC_ALL overrides LANG or LANGUAGE=
                    I just have to fix my alias…
                    would u be willing to test the fix… no changes to your local running system
                    package-lock.json should exist
                    ls package-lock.json
                    then
                    bash -c "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                    when u see the message about saving files, just hit ctrl-c to exit
                      bdream
                      I was to slow for hitting ctrl-c :nerd_face:
                      As this is a huge of lines my buffer is to small.
                      Is there a log or is there no interest to u of the outcome?
                      cheers, bdream
                        sdetweil @bdream
                        @bdream yes the install.log
                        but it should have waited for you to reply about writing over package-lock.json
                        hm… if package.lock.json does NOT exist
                        then create it
                        touch package-lock.json
                          bdream
                          nono, it did exist
                          pi@MagicMirror:~/MagicMirror $  ls pack*
                          package.json  package-lock.json
                          but the script run fast
                          what path I can find the install.log?
                          cheers, bdream
                            sdetweil @bdream
                            @bdream sorry, not install… upgrade.log
                            on the package-lock.json… it is the same as the update… thus why it didn’t stop
                            could edit it an add a space someplace
                              bdream
                              @sdetweil upgrade.log is here from …force… no it isn’t.
                              I can’t copy the 2738 lines in here.
                              How can I bring it to you?
                              And what does this mean?
                              cheers, bdream
                                sdetweil @bdream
                                you can email it , same userid as here on gmail
                                the upgrade should have stopped at the package-lock.json file, just like before…
                                but it didn’t… so I looked back at the 2.9.0 package being installed, and it has a package-lock.json file…
                                so, the one now on the disk is the new one… and a git status will show it hasn’t changed…
                                so, we could MAKE it be different, by using a text editor (like the one you use on the config.js file)
                                and add 1 space character (hit the spacebar)
                                and then save it… then it will be different
                                  bdream
                                  got u mail from me? I would send you logs then.
                                  Is this you ask me to do? and rund your script again to see if it works now?
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream i got one mail and replied. have not got any more
                                    yes, was a way to test. if u can
                                      bdream
                                      if u can
                                      Got it
                                      Upgrade started - Mi Okt 16 20:03:22 CEST 2019
                                      saving custom.css
                                      alias git='LC_ALL=en_US.UTF-8 git'
                                      local version 2.9.0 already same as master 2.9.0
                                      removing git alias
                                      Upgrade ended - Mi Okt 16 20:03:22 CEST 2019
                                      there is no statement about the package-lock.json where I added spaces and saved it.
                                      Seems it works fine :grinning_face_with_smiling_eyes:
                                      One question I have now.
                                      Would it make sense changing the guide for update MM using your script instead of git pull && npm install?
                                      Or is this only a option in case of failure?
                                      cheers, bdream
                                        sdetweil @bdream
                                        if you do apply, then if the versions are the same, it just exits… if you use force then it keeps going…
                                        try with force instead of apply
                                        … once we get this tested I will submit to add to the product… u are helping me test… and I thank you very much!!
                                        i have 3 scripts.
                                        1 updated installer
                                        2 new updater
                                        3 one for fixing pm2 without having to do installer
                                        will submit them all
                                          bdream
                                          Interesting. Now I get 2 package-lock.json listed…
                                          pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                                          saving custom.css
                                          upgrading from version 2.9.0 to 2.9.0
                                             package-lock.json
                                             vendor/package-lock.json
                                          do you want to save these files for later   (Y/n)?y
                                          git: 'git_user_name' ist kein Git-Befehl. Siehe 'git --help'.
                                          audited 220 packages in 23.225s
                                          audited 1 package in 0.999s
                                          npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                                          audited 3475 packages in 88.305s
                                          audited 859 packages in 16.958s
                                          audited 41 packages in 2.814s
                                          audited 41 packages in 3.741s
                                          audited 41 packages in 3.333s
                                          WARNING..
                                          WARNING..
                                          and the log:
                                          Upgrade started - Mi Okt 16 20:15:10 CEST 2019
                                          user requested to force apply changes
                                          saving custom.css
                                          Auf Branch master
                                          Ihr Branch ist auf demselben Stand wie 'origin/master'.
                                          Zum Commit vorgemerkte Änderungen:
                                            (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
                                          	gelöscht:       css/custom.css
                                          	geändert:       vendor/package-lock.json
                                          	%logfile
                                          	core
                                          	css/save_custom.css
                                          	mm.sh
                                          	nohup.out
                                             package-lock.json
                                          save/restore files selection = y
                                          merge result rc= 0
                                           Already up to date.
                                          processor architecture is armv7l
                                          removing git alias
                                          Upgrade ended - Mi Okt 16 20:17:37 CEST 2019
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream cool… don’t know why we got the german there… issued same command back to back, one to log, one to script…
                                            log one came out in german
                                            script one came out in english
                                            fixed a bug, which should have said
                                            any *-lock.json files do not need to be saved"
                                            that is all u had, so you would have selected n, instead of y
                                            • 2 / 3
