    Update to v2.9.0 fail
    48 Posts 3 Posters 18.1k Views 3 Watching
      bdream
      @sdetweil said in Update to v2.9.0 fail:
      hm… if package.lock.json does NOT exist
      nono, it did exist
      pi@MagicMirror:~/MagicMirror $  ls pack*
      package.json  package-lock.json
      but the script run fast
      bash -c "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
      what path I can find the install.log?
      cheers, bdream
        sdetweil @bdream
        @bdream sorry, not install… upgrade.log
        doing test run = false
        update log will be in /home/pi/MagicMirror/installers/upgrade.log
        on the package-lock.json… it is the same as the update… thus why it didn’t stop
        could edit it an add a space someplace
          bdream
          @sdetweil upgrade.log is here from …force… no it isn’t.
          I can’t copy the 2738 lines in here.
          How can I bring it to you?
          And what does this mean?
          cheers, bdream
            sdetweil @bdream
            @bdream said in Update to v2.9.0 fail:
            you can email it , same userid as here on gmail
            the upgrade should have stopped at the package-lock.json file, just like before…
            but it didn’t… so I looked back at the 2.9.0 package being installed, and it has a package-lock.json file…
            so, the one now on the disk is the new one… and a git status will show it hasn’t changed…
            so, we could MAKE it be different, by using a text editor (like the one you use on the config.js file)
            and add 1 space character (hit the spacebar)
            and then save it… then it will be different
              bdream
              got u mail from me? I would send you logs then.
              Is this you ask me to do? and rund your script again to see if it works now?
              cheers, bdream
                sdetweil @bdream
                @bdream i got one mail and replied. have not got any more
                yes, was a way to test. if u can
                  bdream
                  if u can
                  Got it
                  Upgrade started - Mi Okt 16 20:03:22 CEST 2019
                  user requested to apply changes
                  saving custom.css
                  not english or locale not set, set git alias
                  alias egrep='egrep --color=auto'
                  alias fgrep='fgrep --color=auto'
                  alias git='LC_ALL=en_US.UTF-8 git'
                  alias grep='grep --color=auto'
                  alias ls='ls --color=auto'
                  remote name = origin
                  local version 2.9.0 already same as master 2.9.0
                  restoring custom.css
                  removing git alias
                  Upgrade ended - Mi Okt 16 20:03:22 CEST 2019
                  there is no statement about the package-lock.json where I added spaces and saved it.
                  Seems it works fine :grinning_face_with_smiling_eyes:
                  One question I have now.
                  Would it make sense changing the guide for update MM using your script instead of git pull && npm install?
                  Or is this only a option in case of failure?
                  cheers, bdream
                    sdetweil @bdream
                    if you do apply, then if the versions are the same, it just exits… if you use force then it keeps going…
                    try with force instead of apply
                    … once we get this tested I will submit to add to the product… u are helping me test… and I thank you very much!!
                    i have 3 scripts.
                    1 updated installer
                    2 new updater
                    3 one for fixing pm2 without having to do installer
                    will submit them all
                      bdream
                      Interesting. Now I get 2 package-lock.json listed…
                      pi@MagicMirror:~/MagicMirror $  bash -c -i  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)" force
                      saving custom.css
                      upgrading from version 2.9.0 to 2.9.0
                      fetching latest revisions
                      there are 2 local files that are different than the master repo
                         package-lock.json
                         vendor/package-lock.json
                      any *-lock.json files do not need to be saved
                      do you want to save these files for later   (Y/n)?y
                      git: 'git_user_name' ist kein Git-Befehl. Siehe 'git --help'.
                      updating MagicMirror runtime, please wait
                      > magicmirror@2.9.0 install /home/pi/MagicMirror
                      > cd vendor && npm install
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      audited 220 packages in 23.225s
                      found 5 vulnerabilities (4 low, 1 high)
                        run `npm audit fix` to fix them, or `npm audit` for details
                      > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                      > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                      MagicMirror installation successful!
                      > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                      > cd fonts && npm install
                      audited 1 package in 0.999s
                      found 0 vulnerabilities
                      npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                      audited 3475 packages in 88.305s
                      found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                      processing dependency changes for active modules with package.json files
                      processing for module MMM-Carousel please wait
                      audited 859 packages in 16.958s
                      found 2 high severity vulnerabilities
                      processing complete for module MMM-Carousel
                      processing for module MMM-PublicTransportHafas please wait
                      audited 41 packages in 2.814s
                      processing complete for module MMM-PublicTransportHafas
                      audited 41 packages in 3.741s
                      audited 41 packages in 3.333s
                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                      Keine Stash-Einträge gefunden.
                      see installers/stashed_files for the list
                      you can use git checkout stash@{0} -- filename to extract one file from the stash
                      or git stash pop to restore them all
                      WARNING..
                      WARNING.. either will overlay the file just installed by the update
                      WARNING..
                      and the log:
                      Upgrade started - Mi Okt 16 20:15:10 CEST 2019
                      user requested to force apply changes
                      saving custom.css
                      current branch = master
                      Auf Branch master
                      Ihr Branch ist auf demselben Stand wie 'origin/master'.
                      Zum Commit vorgemerkte Änderungen:
                        (benutzen Sie "git reset HEAD <Datei>..." zum Entfernen aus der Staging-Area)
                      	gelöscht:       css/custom.css
                      Änderungen, die nicht zum Commit vorgemerkt sind:
                        (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                        (benutzen Sie "git checkout -- <Datei>...", um die Änderungen im Arbeitsverzeichnis zu verwerfen)
                      	geändert:       package-lock.json
                      	geändert:       vendor/package-lock.json
                      Unversionierte Dateien:
                      	%logfile
                      	core
                      	css/save_custom.css
                      	installers/dumpactivemodules.js
                      	installers/pm2_MagicMirror_new.json
                      	mm.sh
                      	nohup.out
                         package-lock.json
                      save/restore files selection = y
                      test merge result rc='' , if empty, no conflicts
                      executing merge, apply specified
                      merge result rc= 0
                       Already up to date.
                      processor architecture is armv7l
                      removing git alias
                      Upgrade ended - Mi Okt 16 20:17:37 CEST 2019
                      cheers, bdream
                        sdetweil @bdream
                        @bdream cool… don’t know why we got the german there… issued same command back to back, one to log, one to script…
                        log one came out in german
                        script one came out in english
                        fixed a bug, which should have said
                        any *-lock.json files do not need to be saved"
                        that is all u had, so you would have selected n, instead of y
                        • 4 / 5
