    CPU load per module
    6 Posts 3 Posters 2.0k Views 3 Watching
    • T Offline
      teitlebot
      Is there a way to see which modules are using more of the CPU?
        sdetweil @teitlebot
        @teitlebot I have not seen a tool like this
        • T Offline
          teitlebot @sdetweil
          @sdetweil so any idea how I would know which module is causing the smart mirror to lag and stall?
            List your modules here and someone might have a qualified guess.
            Then you can start removing modules one by one until the problem stops.
            • T Offline
              teitlebot
              So I checked my cpu readings using the tool module and it hovers at 40 percent with all modules running and if I disable them all it hovers at 20 percent. Is this normal?
                sdetweil @teitlebot
                @teitlebot depends on the modules… mine hovers around 25%
                most of my modules update slowly
                calendar, weather
